AT897 Shotgun, info please at DVinfo.net
All Things Audio
Old March 3rd, 2005, 11:15 AM   #1
I have a AT897 and it doesn't have an on and off switch. Am I missing something or is the only off switch removing the battery. I don't have phanthom power.
Jon
Jon Omiatek is offline   Reply With Quote
Old March 3rd, 2005, 11:26 AM   #2
You are correct, there is no on/off switch. most professional mics don't have on/off switches. Removing the battery makes it "off" unless you have phantom, in which case it's always "on" until you turn off the phantom. Removing the battery when not using for a long period is a good idea anyway, to prevent potential battery leakage problems.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old March 3rd, 2005, 11:32 AM   #3
Thank you. That is what I thought.
Jon
Old March 3rd, 2005, 01:04 PM   #4
What's the lifespan of the battery in the AT897?
Cliff Hepburn is offline   Reply With Quote
Old March 3rd, 2005, 01:24 PM   #5
African or European? never mind... AT lists 1200 hours as typical. That's 50 days.
Jay Massengill is offline   Reply With Quote
Old March 3rd, 2005, 02:43 PM   #6
LOL,
is that 50 days of usage or 50 days of idle?
Old March 3rd, 2005, 02:52 PM   #7
Lets do the math. 1200 hours would be 50 days. That is great life out of 1.5 volts
Jon
Old March 3rd, 2005, 04:07 PM   #8
If a shoot is of any importance it's a good idea to use fresh batteries on all equipment. My grandson gets the "old" batteries for his Thomas the Tank engines so nothing goes to waste.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting ".......holy smokin rubber lips...what a ride!"
Bryan Beasleigh is offline   Reply With Quote
Old March 3rd, 2005, 04:22 PM   #9
I agree. I always use brand new batteries every 2 times. I will shoot 2 weddings on a set and then I use them in my MP3 player. :)
Jon
Old March 5th, 2005, 06:00 PM   #10
But there's not really any need for new batteries each time on mics like this that use so little power!
Jon
Jonathan Nicholas is offline   Reply With Quote
Old March 11th, 2005, 12:10 PM   #11
It's called CYA-Cover Your Ass. New batts = no screw-ups.
Batteries are cheap, screw ups are expensive.
Mark Sasahara
Director of Photography
Mark Sasahara is offline   Reply With Quote
Old March 11th, 2005, 02:26 PM   #12
And if you're paranoid (like I am) you test them with a meter that puts them under load and you clean the contacts.... Even new ones can be defective and fingerprints can significantly degrade the connection.
