Unsure about radio mic performance
Hi guys,
So recently I did a shoot where the presenter was interviewing people in a really noisy environment (club, loud music etc). For this, I used the Sony shotgun mic that comes with the Z5 in a handheld configuration, and I was presently surprised at the performance. Now, I need to free myself from being wired to the presenter, so I want a wireless system - I'm looking at the Sennheiser G2/G3-type systems, but the hand held mic/transmitter is a dynamic type, and less directional than the shotgun mic on the camera - so I'm not sure whether there will be enough gain/sensitivity/rejection. I don't want the presenter to have to shove the mic up the interviewee's nose! Does anyone have any experience with the Sennheiser (or other) units in similar scenarios? Do you get reasonable quality audio from those mics? Thanks, |
Hi Ben I really rated the mic that comes with the Z5/7 so when I went to P2 I wanted a similar mic.
The Audio Technica AT875 is virtually identical to the sony and I now use it with a G2 SKP500 plug in transmitter that also provides phantom power. The mic is here: AT875R, Audio Technica 875, 875R G2 transmitter:Sennheiser SKP 500 G2 Plug On Transmitter - 009786 I use them together with a rode PG2 pistol grip and a W/S6 wind gag. I also have some of the sennheiser stick radio mics but they are hyper cardioid and really only suitable for vocalists as they are too tight to be used as interview mics.
Over 15 minutes in Broadcast Film and TV production: http://www.imdb.com/name/nm1044352/ |
Thanks for the post, Gary.
Yes, I've now seen a couple of options for phantom powering and wirelessly transmitting *any* mic now, and they look like a good bet. The SKP500 is quite pricey though (as are most things in this business, I guess). I still like the thought of a more robust presenter's mic though. I had a chat to a couple of different hire companies about this, and it seems while the Sennheiser handheld mic/transmitter won't be as sensitive or directional as a phantom powered shotgun, they would certainly be better than a bog standard dynamic like an SM58 or equivalent, which was encouraging. It's always difficult to know unless you actually get the gear and try it out - in this case, hiring and hoping for the best. It would be nice to know what's the typical, "industry standard" type configuration in this area... |
On this side of the pond, the "standard" TV reporter's interview mic is the EV RE-50, usually hard-wired, with a butt plug or H/H transmitter body . In a noisy club the presenter would need to have the mic very close to mitigate the ambient noise. Or possibly a SM58 type cardioid, but the presenter would have to be very vigilant in keeping the mic on-axis and consistent.
The Sennheiser G2/G3 has an excellent reputation as a good system if your on a budget. And like any wireless system, proper gain staging and frequency selection are necessary for optimum performance. (a few minutes of pre-production set-up on location) |
#5 | |
Good news, Cousins! This week's chocolate ration is 15 grams! |
#6 | ||||
Cheers for the replies, chaps! |
#7 | |
6 inches is fine, and is practically what you can expect in those kinds of environments. |
#8 |
The MD46 is cardioid, most of the in-built Sennheiser hand-held transmitters are hypercardioid and have sensitivities more designed for singing in PA environments.
The most common place to see an MD46 is a sports broadcast if the talent isn't using a headworn Sennheiser mic/headset or if they are conducting an interview with a hand-held mic. The MD42 is omni. |
