Wireless headphones to monitor the incoming audio to camcorder at DVinfo.net
All Things Audio
Old April 12th, 2010, 09:17 AM   #1
Do you folks use wireless headphones to monitor the audio while recording video? I find it happen more than one incident where I step away with the headphone connected to the camcorder. It can get ugly, though nothing bad happened to me yet :)
Luke Ho is offline   Reply With Quote
Old April 12th, 2010, 09:34 AM   #2
You too, eh?! I have no answer for your real question, but I just thought you'd like to know you're not the only one courting disaster (or, in my case, ridicule's more common) by forgetting you're wearing headphones... :-)
Hamish Reid is offline   Reply With Quote
Old April 12th, 2010, 10:36 AM   #3
When working with a friend doing steadicam-type shooting on his independent projects, I have used an inexpensive FM transmitter and an FM Walkman receiver to monitor the camera that was receiving a wireless mic signal. The audio quality is surprisingly good, but the max range was only a little over 10 feet.
That was perfectly adequate for this no-budget function, but was not a professional solution.
The transmitter was a battery-operated Belkin model that's designed to transmit an mp3 player's headphone output to you car radio if the radio doesn't have an AUX input.
If I used a headphone extension cable between the camera output and the transmitter, even though it was bundled up it acted as an antenna and provided a few more feet of reliable broadcast range. Since I was always standing only a few feet behind him it worked fine and fit his budget, which was $0.
Most good field headphones have a coiled cable. So that gives you some warning when you start to walk away.
Jay Massengill is offline   Reply With Quote
Old April 13th, 2010, 07:05 AM   #4
I use the Sennheiser MX W1. It's a little pricey and there is a slight delay in the signal but it works as advertised. I love it.
Fred Tims is offline   Reply With Quote
Old April 13th, 2010, 07:13 AM   #5
Woah! I really like the small platform of the MX W1 transmitter so that it can ride on the camcorder, but $500 is a bit too steep. I guess I'll keep looking around.
Thanks for the inputs, all.
Old April 13th, 2010, 07:35 AM   #6
Fred,
How do you power the MX W1 transmitter on your camcorder?
Gabor Heeres is offline   Reply With Quote
Old April 14th, 2010, 06:59 AM   #7
There is a rechargeable internal battery.
Old April 14th, 2010, 10:34 AM   #8
Keep in mind that if you are using a wireless connection to headphones, that if you hear a drop out or some other problem in the audio, you have to figure out if it was a problem in the actual audio, or just in the wireless connection to the phones. I want to be able to monitor my audio, not a wireless jump to some other device.
YMMV.
Rob
Rob Neidig is offline   Reply With Quote
Old April 14th, 2010, 12:29 PM   #9
Wireless headphones are not a good idea.
Sony 7506 headphones are the industry standard. You want clean accurate sound, which the 7506' provide. They are cheap, durable, and have a long cable that coils. Wireless headphones are used for listening to music in your home. The most likely have a bump in the lows and the highs to tickle your ears. You don't want that when recording on a set. You want accurate.
Just try to remember that you are wearing headphones and you'll be fine.
My Work: http://www.youtube.com/ChadWork1
Sony FS5 :: Panasonic GH4 :: Sony PMW-EX1 :: FCPx :: AT4053b :: Rode NTG-3,
Chad Johnson is offline   Reply
