Z1 mic at DVinfo.net
All Things Audio
Old May 14th, 2010, 03:45 PM   #1
Z1 mic
Hi all
what shotgun condenser will fit in the Z1 mic holder?
i was looking to buy rode ntg 2?
I want to use it instead of purchasing a boom pole and hiring a sound operator
Ollie Walton is offline   Reply With Quote
Old May 16th, 2010, 03:54 AM   #2
I don't know the specific answer but I would recommend that whichever microphone you buy you also buy a proper spring-suspension shockmount for it. There is one which fits into the Z1 clip, though I can't recall the manufacturer. The Z1 mount transmits too much handling noise for my liking and the additional mount also swings the mic further away from the lens..
Philip Howells is offline   Reply With Quote
Old May 16th, 2010, 05:06 AM   #3
Rode makes 2 types of shockmounts which work with the NTG-2. One mounts in the shoe mount, while the other mounts in the mic holder.
If it's going to be used in place of a boom pole then it's best to have it shock-mounted. The only time I wouldn't bother shock-mounting is when it's not your primary source (ie you have another mic plugged in) and you just want that mic as a back-up or sratch track.
I would recommend either the Rode NTG-2 (batteries or phantom) or NTG-1 (phantom power only). Great sounding mics for the money.
John Wiley is offline   Reply With Quote
Old May 18th, 2010, 02:13 PM   #4
Originally Posted by Ollie Walton View Post
Hi all
I assume you understand the ramifications of using a camera mic opposed to a boom pole and/or hiring a sound operator. The sound would be far different in most instances, no matter what mic you choose. That said, I also recommend using a shock mount.
Old May 18th, 2010, 04:45 PM   #5
I own the z1 and the mic holder has "wiggle room" to fit most any non hand held condenser mic.
Pete Cofrancesco is offline   Reply
