Recording Dialogue On-Set: A conversation - Page 2 at DVinfo.net
All Things Audio
Old December 21st, 2010, 11:50 PM   #16
label it as wild sound we start with 1000, 1001,1002, depending on what the script supervisor wants. also verbal i.d as wild sound for scene whatever "having tea"
Sacha Rosen is offline   Reply With Quote
Old December 22nd, 2010, 03:11 AM   #17
Sound recordists commonly use the same mic as they're using on the boom for wild effects, unless they're using radio mics or lavalier mics (these aren't used for effects). They're often under time pressures, so the boom mic tends to get used unless it's a more specialised sound effect.
Room tones and atmosphere tracks are commonly recorded in stereo.
Old December 22nd, 2010, 03:42 AM   #18
Slash Rules!
I think someone mentioned logging/slating these wild sounds without a slate, i.e. not enough people to properly slate on cam. An easy trick is to shoot the mic during these wild sounds. Even better, shoot the objects making the sound.
Old December 22nd, 2010, 11:22 AM   #19
In general, I'd use the same mic in the same space. A hyper is good indoors while a shotgun is good outdoors. You could also use a large diaphragm condenser indoors. A Rode NT1A is a great choice if the levels aren't too high. It has an extremely low noise floor, which is perfect for recording foley sounds. And with a cardioid pattern, you can get it closer to the source. Of course, when the sounds are recorded close, the mixer will need to add reverb to put the object into the space.
Here's a video where I recorded a quiet foley sound with the NT1A to compare recorders:
Jon Fairhurst
Old December 24th, 2010, 02:51 AM   #20
Great video Jon. Very slick, in the best possible sense of that description. I really liked the music.
Thanks for the link; amazing to know what's 'out there'!
Mig
Miggy Sanchez is offline   Reply
