Is there ever any real reason to record at 96/24? - Page 2 at DVinfo.net
All Things Audio
Old December 12th, 2010, 12:13 PM   #16
In my audio studio I tend to record everything in 24 bit 96K simply because I can, and that's the default resolution unless you change the preferences. With processor power and storage not remotely a problem, then tell me one good reason NOT to record to the highest quality you can? I'm not remotely suggesting I can hear much above 14KHz as due to my age, above that is lost forever - but I do know that when I get mid 90s 16/48 DAT and ADAT tapes off the shelf and mix them with newer material I can hear a difference.
If I understand what is being said here, it's good to shoot HD even if you only need SD but there's no need to take advantage of better audio, because 16/48 is good enough?
I can assure you that pro studios world wide ARE recording in 24/96 - and a quick look at pro audio (recording and live) equipment shows the format is well established.
With cat 5 and fibre cabling systems, 24/96 is the standard audio transfer protocol now.
In fact - even the home and educational audio world is happily producing on 24/96 - so I have no idea where the notion that they are not has come from?
Old December 12th, 2010, 12:27 PM   #17
Hm, so what I'm gathering is that while there may not be a compelling reason to record at 96kHz, neither is there any real reason not to, and you might as well get your original source files in as high a quality as possible because you never know what you might want to do with them at some point. So the minor workflow issues in Premiere are just something you deal with and no reason to compromise your initial recording quality, even if you're just using a Zoom with non-optimal mics.
As someone who's always advised others to shoot in HD even if delivering SD, I feel hypocritical to not follow that same advice with audio. I've been recording 24/96 up until now, so I suppose I may as well stick with it.
Old December 12th, 2010, 12:44 PM   #18
All recording at 96kHz does is to extend the top frequency response up to about 40kHz.
Seeing as most people cannot hear above 18kHz anyway, and others much less than this.....
The only advantage 96kHz has is that you can use gentle filters instead of brick-wall ones and minimise the risk of things happening in the audible spectrum.
John Willett - Sound-Link ProAudio and Circle Sound Services
President: Fédération Internationale des Chasseurs de Sons
John Willett is offline   Reply With Quote
Old December 12th, 2010, 01:00 PM   #19
Yeah, CDs deliver at 44.1 kHz, so music production should be done at that rate. Film is 48 kHz, so sample dialog at 48.
An interesting factoid is that music samplers are used in almost all films today. It's the primary music source in low-budget film. In TV, you generally get samples with a few live soloists. For big budget films, you'll record an orchestra and they will still mix in samples. All of the most expensive, large sample libraries are made for film, rather than for CD music.
And what rate do the samplers work at? 44.1kHz! So much for purity... ;)
Jon Fairhurst
Old December 12th, 2010, 01:56 PM   #20
Hmmm. I've been scratching my head about where 96kb entered the picture and then recalled that 96/24 (Actually up to 192/24) was supported by Audio DVD which never seems to have really happened in any big way SACD may also have been a reason for going to higher sampling rates - also not a big seller, although I think there are a few thousand titles on the market.
There have been a raft of studies done that seem to indicate that nobody can reliably tell the difference between the higher sample rates.
So the more I think about it, maybe I'm crazy to think 96k yields any real benefits - but I also don't see any reason not to stick with what I'm happy with.
Edit: And by the way, "something" about CD sound annoys me and drives my pianist wife nuts. She's always yelling that digital sound is "cold". So I got a CD player with a tube final stage and now I don't hear any complaints. The problem with all this stuff is that we're dealing with perception - until there's an ISO standard brain/ear combination I don't see that changing.
Old December 12th, 2010, 11:30 PM   #21
I've got a DVD player that plays DVD Audio. I bought Yes, Close to the Edge in both CD and DVD-A formats.
I can definitely hear the difference - when I'm paying attention. The main difference is the clear-as-a-bell soundstage. The image is muddier on CD. That said, for casual listening, I wouldn't care, which is why I didn't run out to buy a bunch of DVD-A discs. I don't tend to listen to music with my head clamped in the sweet spot - unless I'm composing/mixing/mastering my own stuff.
The thing about film is that it is delivered at 48 kHz. You could sample at 192 kHz, but you need to deliver at the lower rate. So why introduce a resampling filter into your chain? Why not just record at 48 kHz and avoid an unnecessary level of digital processing?
Jon Fairhurst
Old December 13th, 2010, 06:05 AM   #22
"Is there ever any reason to record at 96/24?"
Only unless you have a source which in itself is extremely rich in harmonics and so has sidebands outside the "hearing" spectrum thus minimising the folded sideband and resultant artefacts. But only the real golden eared individual could truly differentiate between the two. But in most blind tests, few could, can, might. Although the "muddied" colouration effect is often the first identifier.
Broadcast spec is 48Khz sampling at 24 bits. But yet again gear "specmanship" rears its head through the marketing message promoting 96 is "better" than 48.
In addition, if you are involved in recording such sources and use a long post chain, then there is some justification. I believe MTV Nashville at the MTV Music Awards did a 96Khz recording using the Lawo MC (squared) console @96Khz sampling, but their end product in addition to "to-air" was targetted at DVD sales and involved post sweetening and production.
Some mid-range console manufacturers a while back (and I'll leave you to identify them) wanted to isolate their competitors by offering this concept in the broadcast side of the business - but it was always particularly prevailent and appealing to the music boys and gals. Problem is, 96K sampling eats processing resources, when 48K is more than adequate in the majority of situations.
Finally, and for most product delivered by the many who frequent these boards, customers will always give critical analysis of the images and the video long before they turn their attention to critiquing the audio.
Therefore, is there any real benefit and value in 96K delivery - does the customer really benefit, or does it simply satifisy a golden eared ego?
Women don't hit harder, they just hit lower!
Claire Buckley is offline   Reply With Quote
Old December 13th, 2010, 11:07 AM   #23
Thanks Jon and thanks to you also Claire
This is all very interesting. Personally, I do a lot more audio only than audio with video. Classical music is not usually very visually exciting - sort of a bunch of people dressed like penguins just sitting there wiggling their fingers and puckering, etc. And sometimes the backside of a conductor wiggling his or her - well you know.
By the way - sort of OT but I've been watching the London Symphony masterclasses on You Tube lately and have been struck by the atrocious sound. Of course, some of the atrocity is thanks to You Tube itself, but I'm talking about things like hearing the instrument clearly but struggling to hear the almost inaudible and muddy voice - seems like they've set the mic for the instrument but nothing for the performer him/herself. You'd certainly think an outfit like the LSO could get it right!
Oh well, as we enter the age where everybody's idea of audio is a pair of $11.95 computer speakers competing with the system fans and probably a TV running at the same time maybe none of this matters much anymore
Old December 13th, 2010, 11:52 AM   #24
To be honest, I didn't expect John to side with the lowest denominator approach. I certainly don't subscribe to the quite insane hi-fi/audiofool understandings but why are we not applying the 'record as high quality as possible' approach to audio? My hearing at 50+ is lacking harmonics now, and a 17KHz tone that drives teenagers wild is totally inaudible to me, but surely the more gentle filtering and other small benefits of increased bit rate have a beneficial effect on what we can hear? Why measure a microphone's top limit, if it's above what we can hear? Would we get away with the Rolls Royce approach - Top limit? Higher than you can hear, sir!
All I can say is that my recordings today sound better than those made in 1995. I don't know if it's the result of the higher bit rate, the extra bit depth from 16 to 24, or just better kit all round. For me, the extra headroom with more than 16 bit recording does help with level 'pushing' not being quite so critical. It only seems to even raise it's head when I'm editing in Sound Forge - and copy an old file into an empty new one - when I get the message warning me. If I need a different format to drop into a video, it's no great shakes to produce one. Virtually all my video projects end up in SD or on DVD, but shooting HD is a small amount of futureproofing.
Old December 13th, 2010, 12:26 PM   #25
Ethan Winer has a good presentation on Audio Myths and human perception. It's an hour long, but it's really good info to consider when thinking about these highest quality recording parameters. 24/44.1 is good for most audio things, and bump that to 48k for video. 24 bit is important in that it allows you to record at lower levels without dipping into the noise floor. But recorded correctly (with a good strong signal), 16 bit can sound just as good. 96k (double 48k) can be dithered down to 48k nicely at the final process of the mastering stage. I don't like that many recorders dropped 88.2 (double 44.1) which dithers down more gracefully for CD output. So I and many more just keep the sample rates at the setting of final delivery, 48 or 44.1, though starting out at 24bit, then dithering to 16 after all mastering is done. Classical music has so many wonderful overtones and harmonics happening that the higher sampling rate may just grab some more of that info cleanly enough for us to appreciate - given that one's mics are placed well and your gear is nice enough to move sound through without molesting the signal.
For the most part, we hear what we want to hear when attempting to judge these higher sampling / bit rates.
YouTube - Audio Myths Workshop
My Work: http://www.youtube.com/ChadWork1
Sony FS5 :: Panasonic GH4 :: Sony PMW-EX1 :: FCPx :: AT4053b :: Rode NTG-3,
Chad Johnson is offline   Reply With Quote
Old December 13th, 2010, 01:05 PM   #26
Given a preamp capable of more than 16-bit S/N ratio, and a final delivery at higher than normal sampling rates, I'd be all for recording at 24/192 or whatever. And, if I'm going to re-pitch the audio - especially when turning a kitten's meow into a dinosaur roar - I recommend recording at the higher sampling rate.
That said, the original post was about using an H4n, which has a front end capable of about 14-bits of S/N. And the audio wasn't going to be re-pitched. 16/48 would likely sound just as good as 24/48, though I'd probably do 24-bits anyway if memory weren't a concern. And recording at 96 kHz is unlikely to sound better when delivering at 48 kHz and might actually sound (very slightly) worse, depending on the downsampling filters.
Imagine that somebody recorded some audio and asked you to critique it. You might hear clipping, distortion, a high noise floor, room echo, comb filtering, bad EQ, a bad mix, and so on. You might hear some zipper noise, if they used 7-bit MIDI controls to do a fade out. But you'd never say, "you recorded this at 48 kHz rather than 96, didn't you?"
Then again, you might sense that the recording is dull and lacks that "it" factor. This could be due to a so-so mic, an amateur player or actor, a low-end preamp, a poor A/D, clock jitter, poor plug ins, and/or poor monitors and room.
Maybe with a specific model recorder, you can get a hint of that "it" factor by recording at 24-bits vs 16 (even if the preamp noise is high), or by recording at 192 vs. 48 kHz. But now we're out of the realm of theory and into the sound of a specific piece of gear. At this point the only way to know the difference would be to record some tests at the various settings and to do some blind listening sessions.
Maybe the H4n's clock is more stable when recording at 96 kHz. Maybe it's anti-aliasing filter is better for 96. Then again, maybe at that setting, you get more crosstalk from the electronics. The difference could even be peculiar to your specific unit.
So, while we can talk about theory, if you really want to know the best approach, you need to test with your own gear. And, if you can't tell the difference, don't sweat it. There are lots of things (mic, mic placement, levels, EQ, effects, mix, mastering) that you can hear and that really do matter.
Jon Fairhurst
Old December 13th, 2010, 03:29 PM   #27
Thanks for all the great info and viewpoints. I'm enjoying the hell out of this debate, even if I am just as confused as before I posted. The great thing about the audio experts (which I obviously am not) is that you can ask what you think is a simple yes/no question and get passionate positions around four different answers -- yes, no, sometimes and maybe.
I'm just going to sit back and try to absorb some of the collected wisdom on display here.
Now if you guys could weigh in on my mic recommendation issue posted here, I'd love that.
Thanks everyone.
Old December 13th, 2010, 05:12 PM   #28
Adam I would say that the mic built in on the H4N are pretty chintzy. Nice for song idea capture, but for a real show you should invest in real mics. If you can't afford to buy mics then there's no reason to ask the question. But since you asked, I would say a pair of Rode NT5 mics would do the job for decent stereo at a decent price. More handy is the NT4 stereo mic. Same capsules built into one X/Y stereo configuration. About 100.00 more, but also runs on 9v, battery, so no need for phantom. You have more placemet options with the matched pair of NT5s. Also I would recommend 4 mics across the stage to get full coverage, but it sounds like you want stereo.
24bit 44.1 (audio only) or 48k (for video) will suffice.
Old December 15th, 2010, 01:04 PM   #29
LOL
Actually I normally record at 24/96.
But I do know that many classical recordings are done at 24/44.1 with the thinking that it is better to record at 44.1 than to sample-rate convert down from 96 or 192.
Old December 15th, 2010, 04:21 PM   #30
Hmm. This is all really quite interesting. I wonder just how bad the sample rate conversion really is with today's systems.
Also occurs to me that the 24/96 recording strategy is best if you may want to re-purpose the material, ie burn a few CD's at 44.1, lay the sound track in with video at 48 and maybe even put it on DVD Audio or SACD or whatever else comes along some day. Maybe just distribute on SD cards or something or download to a system that's connected to your regular stereo system.
You could probably make the same argument for 24/192, but I haven't felt much urge to go there yet.
But back to the first point - how do they actually do the re-sample - if it's the logical equivalent of D (at 96) to A to D (at 44.1) I'm not sure I would expect any noticeable degradation - if they were using high end hardware.
Anyone for 32/384 or 64/768????
Jim Andrada is offline   Reply
