Zoom H2 users... - Page 2 at DVinfo.net
All Things Audio
Old August 2nd, 2011, 02:37 AM   #16
Re: Zoom H2 users...
Thanks Stan for that information,
I use Edius BTW.
Thanks again.
Anthony McErlean is offline   Reply With Quote
Old August 2nd, 2011, 05:34 AM   #17
A clapper slate at both ends of the take makes it easier adjust length. Clap a slate at the start as usual plus clap a tail-slate at the end. Line up the visual clap and the waveform spike at the start of the take, move to the end, and line up the tail-slate spike by dragging it.
Old August 2nd, 2011, 07:48 AM   #18
A tail slate definitely makes it easier, but my older H4 exhibits variable drift. So even if you've lined up both slates properly, looking closely at different points in the middle of very long takes the audio may be a little ahead or a little behind or right on the money. Some smaller cuts during the program are usually required to keep things as close as possible throughout the whole run.
My newer H4n does much better. It's not off by much and seems to be consistent and easier to adjust for.
Jay Massengill is offline   Reply With Quote
Old August 2nd, 2011, 03:39 PM   #19
Definitely. The right way to do it is to use pro gear such as SD recorders that have a very accurate timebase to begin with or even better, cameras with genlock input and audio recorders with wordclock input plus the necessary outboard gear like Lockit boxes to sync them all together to a common timebase.
Old August 2nd, 2011, 05:33 PM   #20
Any digital device shouldn't do that. Variable drift is a trait of analog recorders. Something is not right if the drift isn't constant.
Stan Harkleroad is offline   Reply With Quote
Old August 3rd, 2011, 05:38 AM   #21
In theory, variable drift simply means that the time base isn't perfectly stable. And nothing is *perfectly* stable... although an atomic standard comes reasonably close. ;-)
Whether or not the variable drift is noticeable is another question. Even a crystal timebase is subject to some drift, based on temperature. (Most broadcast transmitters, for example, have their crystal timebase inside a temperature controlled oven, to improve the frequency accuracy and stability.) So if a given recorder has an inexpensive crystal at ambient temperature, or, worse yet, a lower cost ceramic resonator, it can potentially drift around over a long period of time.
Old August 3rd, 2011, 08:40 AM   #22
Plus we sometimes forget in this discussion we're always talking about TWO timebases, not just the one in the audio recorder but also the one in whatever we're matching it to.
I'm also referring to 90 minute live recordings where there has been minimal warmup time for the equipment before recording begins, and the air conditioner cycling off and on many times during that period, with very noticeable differences in the air temperature during these cycles.
Old August 3rd, 2011, 10:08 AM   #23
Even two (or more) cameras of the same make and model will drift some over time w/o being 'gen-locked'. For continuous multi-camera A/V recording, it's best to use a tri-sync system... if it's in the budget.
For feature film type work, where there are many short scenes and takes, drift is usually not an issue. Even with the notoriously flaky RED camera and an H2.
Rick Reineke is offline   Reply
