Can xlr channels be swapped?
Seems like a no brainer, but this is the first xlr mic I've used, so no brains is about where I am on this :-)
Is there any reason not to switch the XLR inputs to opposite channels and then turn the mic so it faces backwards? That way left stays left but then the mic is closer to my mouth. The cam is a Canon XA10 and the mic is a stereo Sony ECM-MS2. Thanks. |
Re: Can xlr channels be swapped?
As a purely technical question, you are absolutely correct, the channels can be switched to preserve the "soundstage". Or, most video editing software provides a way of doing this after the fact, also, so there is more than one way to accomplish this.
As an artistic question whether that is the right microphone or a proper application, you will have to be the judge of that. |
Thanks. Mic looks funny but it will work for now. Just wanted to make sure there was nothing about the balancing or phase that would be upset. Good news.
Yes I will definitely be using that. Appreciated! For now I am just trying to get the understand the mic characteristics.
Funny thing, the mic creates a low frequency distortion with voice. Guess I noticed it when moving it closer to my mouth. Don't intend to use it for long for voice, since that is not its purpose. I found that with the current arrangement, the camcorder attenuator is needed to get the sound clean. Then I turn up the volume on playback. Is that right? |
Nick,
Want to learn about audio? Then invest in Ty Fords or Jay Roses book. they can answer all of your questions. not that the guys and gals here can't but those books are great guides to keep handy and read all the time. |
FYI your 'low frequency distortion' is an illustration of a characteristic of directional mics called 'the proximity effect." It is an inherent behavior of all directional mics to a greater or lesser extent. The ECM-MS2 is a mid/side stereo mic that consists of two capsules, a directional cardioid capsule for the 'mid' portion and a figure-8 capsule for the side. When the mic is close to the sound source, the mid cardioid capsule will start to exhibit this proximity effect which manifests itself as a boost in bass response. The closer it is to the source, the more pronounced will be the bass boost.
Just ordered one of Ty's books in very good condition for 2.99. :-) Thanks for the tip.
Does the low freq distortion apply to lapel type mics? I am obtaining an Azden 3 channel field mixer in the coming weeks in order to add the extra channel. Wondering if I will have to deal with a few possible issues. Will the 3rd channel for voice mix poorly with the vocal that the stereo Sony picks up? Are clothing and moving around noises a problem for lapel mics? |
| All times are GMT -6. The time now is 02:43 PM. |
