Question about using 2 wireless systems at DVinfo.net
All Things Audio
Old February 7th, 2013, 07:01 PM   #1
I have an Azden 310LT system in the 566.125--589.875 range. If I wish to add another and use at the same time, can I get the same "UHF range" and simply select different frequency? These systems provide 188 UHF selectable frequencies.
Darryn Carroll is offline   Reply With Quote
Old February 7th, 2013, 08:25 PM   #2
Re: Question about using 2 wireless systems
Yes you can. I've used the Azden 500U some years ago with up to 6 units running to a board and as long as there is seperation of frequencies and nothing else in the area of the freqs you're using you'll be OK. Obviously it would be best if all the ranges/freqs were as far apart as possible but in practical terms that isn't always feasible.
Don
Old February 7th, 2013, 08:28 PM   #3
Thanks Don, I will shoot for freq's at the top and bottom of the range.
Old February 8th, 2013, 10:28 AM   #4
"I will shoot for freq's at the top and bottom of the range"
- That's really not the best way to select frequencies. I don't know about your Azden system, but most frequency agile system receivers have some kind of scan function for finding an 'open' frequency. RTFM.
Old February 9th, 2013, 04:25 AM   #5
They may have 188 frequencies, but *not* 188 usable frequencies!
You need to talk to the manufacturer and get a list of intermodulation-free frequencies that you can use together at the same time and only use those frequencies.
Scanning may help - but you *must* choose a frequency that will not cause any interference to the others you are using.
John Willett - Sound-Link ProAudio and Circle Sound Services
President: Fédération Internationale des Chasseurs de Sons
John Willett is offline   Reply
