Sound Devices 302 weird clicks/pops at DVinfo.net
All Things Audio
Old May 5th, 2013, 01:57 PM   #1
Slash Rules!
Hey guys. Not too long ago got a sound devices 302 off ebay. Checked it out when it first came, seemed like everything worked flawlessly. Used it once to help with some music recording, no issues. Was using it today and while monitoring the recording devices (a Tascam DR07) through headphones, kept hearing these little "crackle" or "pops". Thought it might be the rubbery stuff on the headphones. . .nope. . .I was actually seeing it on the mixer's meters. Thought it might be interference on the Sennheiser G2 lav I had hooked up to the mixer. . .nope, still saw the pops registering on the mixer's meters. Finally, unplugged/turned off everything except the mixer. . .it was the mixer itself! I had nothing hooked up to it, but I could still see the meter registering the little random clicks/pops. So it was something inside the mixer? Then I turned it off, and when I turned it back on, it stopped doing that.
Anyone ever heard of this? This is the first time it's done this to me. Battery light was green (using AAs).
Old May 5th, 2013, 02:26 PM   #2
Re: Sound Devices 302 weird clicks/pops
Have you tried turning the input gain knobs one by one to see if that was the source of your pops? Those pots could be dirty and may be the first culprit.
Old May 5th, 2013, 03:13 PM   #3
Can we hear it?
Did you try changing the batteries?
Jeffery Magat is offline   Reply With Quote
Old May 5th, 2013, 04:40 PM   #4
If all else fails, contact Sound Devices support they're very helpful ..
Support | Sound Devices, LLC
Cheers.
Old May 5th, 2013, 04:46 PM   #5
Likely will need to be sent to the mother ship for repair.
Move the trim and faders to hear if that changes.
Old May 5th, 2013, 07:13 PM   #6
Slash Rules!
Damn. That sounds like the issue. I had adjusted the coarse trim before recording. Although just to be clear, this popping was AFTER i had made my adjustments. I was not touching the knobs at the time. Man...i dont wanna nuffin to the mothership. That sounds expensive.
Old May 5th, 2013, 08:09 PM   #7
Praying that my SD 442 does not experience those or any other problems which was also purchased through ebay.
Melvin Baggs is offline   Reply With Quote
Old May 6th, 2013, 11:01 AM   #8
I would call SD Josh.
I vaguely recall those symptoms being reported on a 302 at another forum.
Old May 8th, 2013, 12:06 AM   #9
Slash Rules!
Thanks. Just emailed their support. Like all the best problems, I could not recreate it. When it happened that time I mentioned above, I turned it off and back on, and it was gone. I did some recording and every time I checked the headphones (couldn't wear 'em all the time cause I was acting in this thing) I didn't hear it. Even tried screwing with all the channels' coarse gain pots. . .nuttin. It's like the first act of a horror film for sound guys where nobody believes the ghost is real.
Old May 8th, 2013, 08:00 AM   #10
Josh,
What's expensive is not being able to use broken gear (if it is broken). Sound Devices, as a company, is one of the best out there for service. I own a 442 and a 744T and have known them almost since they started. Do yourself a favor, reach out to them TODAY and get back on track.
Regards,
Ty Ford
Old May 10th, 2013, 01:11 AM   #11
Slash Rules!
Ok, this may well have (surprise!) been pilot error. Looks like I had the inputs on channels 2 and 3 which weren't being used at all switched to phantom power instead of DYN. SD folks said that might have done it.
Old May 10th, 2013, 06:31 AM   #12
Josh,
Thanks for bothering to return with that info. I'm sure others will also find it helpful!
Who'da thunk it.
Regards,
Ty Ford
Old May 10th, 2013, 07:59 AM   #13
Josh, et al...Thanks! I haven't had any 'issues' with my SD-302, but I didn't know SD recommends leaving 'unused' channels switched to 'DYN' position rather then 'Phantom +48 vdc'. That is now part of my "switch-list".
Ty..."Who'da thunk it?" Indeed!
Best regards,
J.
James Kuhn is offline   Reply With Quote
Old May 10th, 2013, 08:49 AM   #14
Slash Rules!
No problem. It's not FOR SURE that that's the issue. . .but it very well could be. Hopefully. I guess I'll know if it happens again and the unused channels are on DYN!
Old May 10th, 2013, 04:24 PM   #15
First time I've heard of that one. Try Googling around eg: ..
SD 302 Phantom Power Crackling Sounds - Equipment - JWSOUNDGROUP
Cheers.
