Closed headphones for loud sets? - Page 2 at DVinfo.net
All Things Audio
Old May 24th, 2013, 02:27 PM   #16
Re: Closed headphones for loud sets?
"As you pick a solution keep heat in mind"
-- I've worked in both extremes and put Garfield Softies on my 7506.... Cheap and easy, warm in the winter, cool in the summer.
Garfield Co. Headphone Softies
I've have not tried one but, Koala Windsocks Soundman Sun Hat are available from the usual suspects.
Old May 24th, 2013, 03:49 PM   #17
If you want the isolation but maybe not so worried about quality, then drum headphones work well (but clamp your head like a vice)
http://www.amazon.co.uk/Direct-Sound.../dp/B0002GZLY2
or dirt cheap ones
Drummer Headphones, CD-500 Manufacturer -- Yoga Electronics Co., Ltd. is a leading supplier and exporter of Drummer Headphones, CD-500 in Taiwan, Asia (less than £40)
DT-100s have less isolation, but sound better. For better quality look at Peltors.
Old May 25th, 2013, 11:18 AM   #18
Interesting you guys mention heat, as the sweat and the heat have just worn the ear covers onmy 7506's to shreds.
I will keep that in mind.
Al
Al Gardner is offline   Reply With Quote
Old May 25th, 2013, 11:53 AM   #19
Another possibility- something I did before I owned my IEMs, is a combination of musician's ear plugs and closed-ear headphones. The 15dB cut Etymotic Research ear plugs are remarkably flat- I've mixed live sound for some very loud shows with them in without issue. The 25s are pretty flat, but not as good sounding as the 15s (but needed in a loud environment).
I've put the 15s in, then turned the headphones up. With the plugs in, the SPLs coming off the cans weren't an issue, but still offered pretty good isolation. Still, though, these are custom molded plugs and while a whole lot cheaper than IEMs, they still aren't terribly cheap (a couple hundred dollars per pair usually with the molds).
--Ben
Benjamin Maas • Fifth Circle Audio • Signal Hill, CA
http://www.fifthcircle.com
Benjamin Maas is offline   Reply With Quote
Old May 27th, 2013, 01:39 AM   #20
http://www.bhphotovideo.com/c/product/283347-REG/Remote_Audio_HN7506_HN_7506_High_Noise_Isolating.html
Les Nagy is offline   Reply With Quote
Old May 27th, 2013, 03:43 AM   #21
Technically those seem like a good solution for some gigs. But shame of Sony for making them white. Why bother wearing show blacks if your cans look like they deployed airbags!
Steve
www.CorporateShow.com
Old May 27th, 2013, 04:05 AM   #22
Sony did *not* make them - they are made by Remote Audio using Sony OEM drivers.
John Willett - Sound-Link ProAudio and Circle Sound Services
President: Fédération Internationale des Chasseurs de Sons
John Willett is offline   Reply
