BiAmped Monitors for iMac? at DVinfo.net
All Things Audio
Old October 6th, 2005, 11:20 AM   #1
What is the best device to connect M-Audio BX5 monitors to my Mac? I assume it would have to be a USB or Firewire D/A driver of some sort? Is that a product which integrates inputs and outputs.
Hopefully this isn't too much of a noob question (only used Sony 7506 phones so far).
Thanks.
dB
Dan Brown is offline   Reply With Quote
Old October 6th, 2005, 01:14 PM   #2
Nevermind, I figured it out (M-Audio Firewire 410).
dB
Old October 6th, 2005, 01:18 PM   #3
Images: 1
Thanks.
Dan,
I just bought a used Tascam USB-122 from a fellow DV-INFO member. I am using it on my Imac G5. Has every type of interface I need and allows for direct monitoring of other stuff plugged into the inputs. The left and right outputs go to my Yamaha near field reference monitors. Has midi, so I can control the softsynths in Garage Band and the effects in Motion. It supplies phantom power for the VO mic I'm using, etc.
More info can be found here.
http://www.tascam.com/Products/US-122.html
good luck,
-gb-
Old October 6th, 2005, 02:03 PM   #4
Thanks Greg, I'll check those out. I wasn't even considering Midi, but if it doesn't cost much more, it might be cool. I mess around with guitar from time to time (no threat to the entertainment industry ;^).
Cheers...
dB
