Making Low Profile Female XLR Connectors
These used to be the exclusive province of the DIY community, but now several commercial varieties are sold. Since I like to make the occasional piece of gear, as I do all of my cables, I decided to take my own stab at making some of these guys. They can relieve congestion in an audio bag, but I made them to tidy up microphone stands that I use to record live performances.
A pictorial 'tutorial' is on my site here. Cheers. Steve
www.CinemActionFilms.com |
Re: Making Low Profile Female XLR Connectors
Very clean! I'm actually looking to do this for a friend of mine soon. I've seen a lot of people mix up colored epoxy instead of using a plastic end cap. Do you know if McMaster offers those caps in different colors?
#3 | |
Because my goal was stealth, not color-coding or bling, black was the obvious choice. Had I needed to make a colored end cap, however, I think I might have painted a cap with model paint or similar. I just didn't trust myself to mix a colored epoxy and have it cure without making a colossal mess of things. If you make some connectors, please post your results.
I'm making them to go in an audio bag, so color-coding is important! I'll post here when I make them.
#5 |
If you just need to ID different cables, just put a 1" - 2" length of colored heat-shrink on the cable, where it enters the connector. Lots of colors available, and much easier than mixing colored epoxy.
#6 |
Making low profile XLRs has been discussed over at the JWGroup, (search). Lots of photos, parts,vendors and design idea to be considered.. The pre made low profile connectors are nice but are relatively expensive (Kortwich cable = $80) compared to modding a standard $3 Neutrik plug.
#7 | |
#8 |
Would a pipe cutter work for trimming the case? Less tooling marks than a saw, less work to deburr.
#9 | |
Really, the band saw or even a hack saw don't leave tooling marks and sanding these soft aluminum connectors is very easy. My example above truly was the worst cut I've made since I started to make these connectors. That may or may not be related to my consumption of wine during its manufacture.
#10 |
There is a simple pipe deburring tool that quickly removes the internal burr. Anybody who uses a tubing cutter should have one of these.
Wheeler Rex 920 Pocket Deburring Tool Reamer Pipe Tubing Copper Aluminum | eBay |
#11 |
That de-burring tool is highly recommended. I'd also recommend using a dremmel tool with the proper "bits" for fine tuning the length and cuts as needed. It's pretty impressive what you can do with one of those. I always recommend people pick one up. You may not use it all the time, but sometimes things come up for where it comes in really handy, from odd jobs around the house, to working on your son's pinewood derby cars, to modding XLR connectors.
#12 |
I've drilled a hole on the side of a stubbed connector (near the back), run the wire through the hole and once it was done just filled in the back with hot glue. That keeps the wires from moving around and the whole thing doesn't take very long at all.
Mark Goodsell |
#13 |
My favorite cable/connector vendor, Redco, is now selling commercial version of this connector. Both male and female, both 3-pin and 5-pin. And end-caps available in the 10 EIA colors.
CT-LPXLR-3F-K |
#14 |
I expected a real body looking thing - have to say I'm impressed with these - really neat!
#15 |
Still seems pricey for what they are, but I guess if you figure the time to make one, it's the better way to go especially for any commercial application. Plus, they can be disassembled and reworked if a different cable length/style is needed.
Mark Goodsell |
