xlr cable at DVinfo.net
All Things Audio
Old May 16th, 2017, 05:13 AM   #1
xlr cable
I have a bad xlr cable. Is it something I could fix or is it not worth it. It's a 10', looks cosmetically fine but if the one of the ends is bent it cuts out.
Old May 16th, 2017, 07:07 AM   #2
Re: xlr cable
If the connectors are field serviceable then you can fix it as long as you know how.
Dave Fisk is offline   Reply With Quote
Old May 16th, 2017, 08:28 AM   #3
Re: xlr cable
If you know how strip/tin/dress wire and how to solder you should be able to fix it. You might need a new connector depending on what is inside the bad end.
dpalomaki@dspalomaki.com
Old May 16th, 2017, 09:20 AM   #4
Re: xlr cable
I've seen a lot of those POS molded-on connectors break, which can't be fixed (from a band I work for). If the cable itself is of decent quality, I just solder on a new Neutrik XLR connector ($3 and 15 minutes if you know how). I make my own cables from Canare StarQuad cable stock (about $0.50 / foot) using Neutrik XLRs. Some are 20+ years old and have survived all kinds of abuse on stage, film sets and international documentary sound work.
Old May 16th, 2017, 12:30 PM   #5
Re: xlr cable
Thx everyone I was able to fix it after watching a YouTube video.
It was an Audio Technica cable with a Neutrik end. When I opened it up I could see the problem. One of the wires was too long with the insulation stripped back too far, bending or touching the end, caused it to make contact with another wire. I shortened it, added insulation, and soldiered it back on.
Old May 16th, 2017, 04:54 PM   #6
Re: xlr cable
Congrats Pete. You'll be making you own cables in no time at all. It's actually very simple.. saves lots of $ and aggravation.
Rick Reineke is offline   Reply
