Rode Wireless Film Maker Modification
Some new toys arrived yesterday. Amongst them a Panasonic AG-UX180 and a Rode Wireless Film Maker kit.
I didn't like the idea of having large plugs and messy cabling all over the camera, and I will be leaving the receiver attached so I decided to reduce the footprint of the receiver. I also hate having to use batteries when there is a perfectly good power supply available, in this case the USB host port on the camera. I drilled a couple of holes in the front side of the receiver to line up with the 1/2" threads on the camera's handle and used a couple of countersunk brass screws to attach it with a strip of 4mm ABS plastic in between to space it up a little so it didn't hit the curve of the handle. Electrically, I found some test points I could connect to on the PCB for audio out and 5V USB power. I had to scrape some of the solder resist away to expose a couple of ground points. The power supply needed filtering to remove a small buzz, which I did with a 12 Ohm resistor and a 2200uF capacitor. Finally, I modified a plastic XLR plug to reduce its size and ran the cable out the side. This setup work well and comes on automatically with the camera. I was concerned about the possibility of reduced range because of the proximity to the antennas of the cables I added, but I could not notice any change from my tests before I started the modification. Last edited by Michael Warren; November 30th, 2017 at 10:16 AM. |
Re: Rode Wireless Film Maker Modification
Very Nice!
Probably kills the warranty if that is important, but otherwise interesting.
I suspect tthe same could be done to the Newsshooter kit's receiver. As i understand it the antenna is internal and to the front end (opposite the display end). I suppose depending on their exact position the added wires could even act as a parasitic element in a yagi-type antenna to modifye gain/directionality.
dpalomaki@dspalomaki.com |
I've definitely voided the warranty. As an electronics engineer I do things more complicated than this all the time.
As for the new wires improving the signal, the chances are very slim for that. I did expect that I might have to route the wires away from the antennas. That would have involved cutting out part of the battery compartment, so I tried it as you see in these pictures first. It works fine so no need to go any further. |
#5 |
In case you don't know, the antennas are the 2 gold "F" patterns seen on the far right and top of the photos of the PCB.
#6 |
Equal Opportunity Offender
Is there a mod you can do to enable the receiver to be mounted correct way up on the camera?
Andrew |
#7 |
That would have been more complicated.
Besides, flipping the sound upside down means it will come out the right way for the northern hemisphere. PS: I'm going to be visiting your town in February to see Roger Waters. |
#8 |
There are other receivers which already have this included, such as the Sony UWP-D11 kit can be powered via USB.
http://IronFilm.co.nz/Sound/ (Location Sound Recordist based in New Zealand) http://www.YouTube.com/c/SoundSpeeding |
#9 | |
The main thing is that I didn't want lumpy plugs sticking out all over the place, plus having the receiver on the cold shoe would have made it stick out a long way. The way I have it now the receiver is an integral part of the camera and nothing gets in the way of other operations and setup/pack up. |
