#76 | |
also known as Ryan Wray
Re: Do lavs work at all outside in a city, or not really?
#77 |
In the 1940s and 50s they didn't have the choice of small lav mics. Then they would dub the lines (ADR basically with it being done manually) or they would use back projection and shoot the dialogue in the studio or even build the exterior in the studio as a set. If you look closely you can see it's a set.
They also used a fisher boom So far, you used one example of the lavs v boom, without any details of he shots. The scenario has a the feel of the director wanting to use lavs and the sound man wanting to use the boom, possibly in a situation that suited the latter. Like all these situations you use the tools that's suitable for the job in hand, there are no rules, only what works. If you just turn up with boom and you can't do something you may not be around in a day or two. |
#78 |
Oh okay, thanks. Well for other people's projects, I was the boom operator, and that is what they wanted me for, so I wasn't expected to show up with lavs, when I was the boom operator, was I? Or should I have had lavs as well instead of PSM providing them?
But for my own I can use lavs, especially in the wide shots. |
#79 |
If you're just the boom operator, coming with just your own boom (I'd assume a 15 ft job) and associated accessories would be fine, since the sound recordist/mixer should be providing the microphones.
#80 |
Dam these Ryan threads they get big. Just wanted to stop by and say hi to everyone. Ok have a good day and keep going.
#81 |
Pete - I think Ryan's topics really don't need a title because wherever we start we end up somewhere else!
Ryan - running one radio channel is tricky - multiple ones are really going to push your skill set. As soon as we go to two channels, we start with intermod, and this means retuning, and this means band plans, channel sets and most critically, recognising interference and determining what it is. Many systems have empty channel search features, and they're really rubbish, because they rely on an empty channel staying empty. Radio systems are location sensitive and it only takes the local hotel to power up their DJ system to wreck your planning. It means the person running your system must be the one who hears problems before recording, not discovering them in the edit when it's too late. You need to be able to distinguish between AF issues, RF issues - so that's generally signal strength, intermod and interference. They have characteristic sounds that you need to be familiar with to solve issues. I've said it numerous times, but buying a couple of radio mic systems does not guarantee decent audio in the same way that buying a boom and shotgun doesn't. BIG learning curve Ryan. |
#82 |
Ryan, If you actually wish to learn sound recording for film, there are courses that specialise in the subject. At the moment this. like everything else, is all hit or miss or what someone told you.
#83 |
For the inexperienced radio mic user, the newer GHz frequency systems are usually better since choosing frequencies are not necessary. Pro and cons to all though.. be it VHF, UHF or the GHz systems. No wireless is gonna be perfect 100% of the time no matter how much the cost.
#84 |
Okay sure, I'm much more use to booming then lavs of course, but I can learn the lavs then too. Since I was told that on other projects involving lavs, that the background sound is loud compared to the boom, it was said before on here, that shouldn't since the lavs are much closer. However, could they have been talking about the room tone tracks, and the room tone was picking up too much background noise, compared to the boom room tone track, perhaps?
#85 |
I think you should test lav mics compared to a boom mic. Room tone isn't something I would associate with lavs because they are usually so close to the mouth and can have more bass from the chest. I know one sound recordist who records both.
You still seem to talking about that one scene and treating it as a rule and endlessly repeating it. Test mics for yourself, see what they do, what works and doesn't work, otherwise you're just wasting other people's time. |
#86 |
Okay sure. It's hard to test them without purchasing them first because of covid and all the rental houses here are closed, so I thought I would have to purchase them first.
#87 |
#88 |
If you know any sound people or others that own their own lav mics, you could hire or borrow one from them. There's hardly a rush of productions at the moment.
#89 |
Oh okay thanks, I don't know anyone who has their own, the other productions I helped on, all rented before.
Yeah, and if it's the lav on a mix track, does that mean that they would use the room tone track from the lav, in which case maybe the background sound was too loud on the room tone track for them? |
#90 |
You've got confused again. If you have a static, and stand mounted mic - then the atmos it captures is usable. It's VERY different with a person mounted mic. How much will you record that doesn't have rustles, sniffs and worse - a change in the audio perspective as they move around. Room tone (and I hate that term) is no good if it's not continuous - and what exactly are you planning to do with it?
Given a boom feed and a radio mic feed, I doubt you'd get much useful audio that would be handy for the editor? If you want to specifically record room sound for filler, this takes planning. Can be easily done but perspectives have to match. Those booms were the mainstay of TV and movies for a very long time - and everything was recorded at a distance, and because of proper aiming, the sound was amazingly good! |
