Fostex FR2 with a SD302 mixer? at DVinfo.net
All Things Audio
Old May 2nd, 2006, 07:47 AM   #1
I'm VERY new to sound recording!.....
Can I use/mate a sound devices 302 mixer with a Fostex FR2 field recorder? If so, how?
Phil Kay is offline   Reply With Quote
Old May 2nd, 2006, 08:51 AM   #2
Sd302 ->fr2
The SD302 can have its outputs set at +4dbU - which is the input level the FR2 is expecting (or so it appears from the FR2's specs..).
I'd suggest that you download the manuals on each piece of gear and have a read. The SD302 manual is very helpful; I can't speak for the FR2, as I don't own one... but usually examples are given for setting up the equipment for different recording scenarios.
As you are new to sound recording, I can thoroughly recommend Jay Rose's books on audio for DV. Check them out on www.dplay.com .
Rgds, Ross.
XH-A1; HV-20; Miller DS-10; Manfrotto 695/3229; SD302/702; PCM-D50; FCS2; MacPro; 2.25TB
Ross Jones is offline   Reply
