Using a light diffuser as a pop filter at DVinfo.net
All Things Audio
Old June 5th, 2006, 06:50 PM   #1
Working on a shoestring budget, I always have to find ways of making better use of my equipment. It just occurred to me that I could use my diffuser, which has a lot ot tiny holes, as a pop filter. Is there any reason why I should not do this? Does the material the pop filter is made of make a big difference?
Emre Safak is offline   Reply With Quote
Old June 5th, 2006, 07:40 PM   #2
Possibly
However, pop filters are easy to make. Go get a needle point hoop, the kind that has a fastener on one side. Stretch some panty hose across it and clamp it in with the hoop.
Last time I checked you could both of these things for less than $15 on the web. That really is all a pop filter is.
Make sure though, the light diffuser is a pourous, flexible material. This way you don't get weird sound abberations.
And you should always talk across the diaphragm mic instead of directly into it. This will reduce the majority of your pops and mouth noise.
Tim
Tim Snyder is offline   Reply
