Iriver 895 Sync Issue at DVinfo.net
All Things Audio
Old June 26th, 2006, 07:52 AM   #1
Hello,
I recently recorder a event where I used a iriver 895, vx2000, and vx2100. The iriver was used to capture the entire event. When I attempted to sync the audio from the two cams and the iriver the iriver's audio would not sync with the two cams audio. My question is: Is this common or is there a setting on the iriver that I need to set prior to recording? Btw, I use Vegas 6 as my video editor.
Troy
Troy Davis is offline   Reply With Quote
Old June 26th, 2006, 08:15 AM   #2
How long of a recording was it?
Dave Largent is offline   Reply With Quote
Old June 26th, 2006, 08:16 AM   #3
approx. 2.5 hours
Old June 26th, 2006, 09:41 AM   #4
Was the recorder synchronized to the camera(s) in any way? If not it would not be uncommon to expect the three pieces of equipment (2 cameras and recorder) to drift apart by a frame or 2 over 2.5 hours. This can be compensted for by stretching or compressing the audio as required in a DAW equipped to do this.
Old June 26th, 2006, 09:58 AM   #5
Originally Posted by Troy Davis
approx. 2.5 hours
I would expect around 10 to 15 frames drift
in 2.5 hours would be normal.
Old June 26th, 2006, 07:27 PM   #6
I think there is some kind of voice activated option in the iriver setup menu. It should be off. If it recorded everything, but there were no pauses between the speeches, this might be the problem.
Buddy
Buddy Frazer is offline   Reply
