novie question: loud/quiet/loud troubles!
I'm editing a sequence in a movie where I need to effectively juxtapose footage of quiet, tense dialogue with footage of an incredibly loud, fast, and droning black metal band from another location. I've attempted to reduce the amount of times I need to cut back and forth between the two sets but still haven't found a solution for how harsh the transition hits the ears. I don't know if adding music in the quiet scene will help or hurt or if i should come up with some kind of continuity sound, like a muffled version of the band playing. How can I ease the shock?
That's meant to say novice, by the way.
You might try:
Reduce the band by several db Use a fast cross fade between cuts Cut to the band on a downbeat |
Right. Turn down the band until the balance works. And turn up the quiet dialog a bit.
Ty |
I agree with the previous posters that the actual levels of the two sounds should probably be fairly close to one another. Loud rock will "read" as such even at low levels.
It might (or might not, depending on the scene--I obviously can't see the actual footage, so it's hard to say for sure) also be a good idea to try a few L-cuts from one setting to the other. Maybe the music cuts in as the actor speaking the quiet dialogue finishes a thought, but we continue seeing him for a moment before the video cuts over to the band. Maybe we begin to hear the actor speaking while we're looking at the singer's face. This might actually make the transition more jarring, or it might smooth things out quite a bit, because it will enhance the juxtaposition between the two scenes. The contrasting emotional dynamics of the edits would either blur or else contrast even more. Again, it just depends on the actual footage you're dealing with, but it might be worth a shot. Another thing to consider would be the idea of having the quiet dialogue continue to be spoken off-screen while the band footage is cut in, with the band turned way down below the dialogue. I realize that these are suggestions with/for aesthetic effect, and that you were really sort of maybe looking for technical advice. However, in my experience, technically difficult cuts are often best dealt with by finding a purely aesthetic solution, oftentimes something you hadn't originally thought of. Practically all of my favorite cuts in my own work were things that came out of creative solutions to things I thought would work a certain way when I shot them only to find out that my original idea just didn't quite work. You should never be afraid to completely re-invent a scene in post-production if doing so will improve the scene. It's good to keep a completely open mind while cutting. A maxim of mine has always been "try to plan everything to a ridiculous degree before you shoot, and then get ready to throw those plans out the window when you edit." Your mileage may vary, but this kind of thinking works extremely well for me. |
Try an L-Cut.
In addition to the suggestions to set the levels of the dialog and the music a bit closer to each other, instead of using a simple straight cut, overlap the outgoing and incoming audio by 5 or 10 frames at each edit and do a fast crossfade between the clips.
Was the dialog recorded clean, without the band, or was the band playing in the background while you shot the dialog? In the final scene, are we to understand that the band and dialog are at the same place and time like two spies meeting at a club talking while the loud noise of the band prevents eavesdropping or are the cuts cutaways to show events at thee same time but two different places, say something like Mother and Daughter are in the kitchen talking about Daughter's new boyfriend the Drummer interposed with shots of the boyfriend's band auditioning at the club across town that we understand is going on at the same time? For the first we'd want to have the music running continuously, fading it down during the dialog and up in the spaces and during cutaways. For the second, you'd want to checkboard the dialog and crossfade at the transitions. |
I originally expected that I would need to resolve this problem with some form of processing but I ended up realizing that the conflict between the two sets of footage arose from expectations set by the structure of the song, which involves enough creschendo and motif development that it really needed to play itself out before it could be cut. The song was long enough that I had to do some fine-tuning to shorten it substantially, but this version does more justice to its dramatic clout than cutting away every twenty seconds, and inflicts less fatigue. I also used a crossfade and L-cuts to ease the pain. Thanks!
I've been editing audio for longer than I care to admit. Is L-cut a film term? I've never heard it before. Thanks, Ty Ford |
Yes, it comes from Film Editing. Refers to a edit where the sound portion of the film is preserved. The cut is in the form of an L.
Or in the shape of a J. It depends on if the audio startes early or late.
Put it on your timeline and you'll see the shape for yourself. |
Ty,
An L cut means that the audio relating to a picture continues after the picture ends, and a J cut means the audio portion of the video begins before you see the frame VVVVVVVVV AAAAAAAAAAAA Creates a "J" cut. VVVVVVV AAAAAAAAA Creates an L cut. make sense? |
But hopefully Ty will understand, given the text descriptions that go along with it. -gb- |
1 Attachment(s)
Well...it looked right when I typed it, but you're right, it doesn't display correctly. Oops.
I'm sure he'll figure it out. Just in case, here is a pic from my Vegas book. ;-) |
We have another Vegas book coming reasonably soon. |
I admire you guys. I revised a book from Premiere Pro 1.0 to Premiere Pro 1.5 and it was more work than I ever want to do again. I found my niche. I get paid to follow the instructions in other people's books as they write them. Not as much money, but much easier, by far.
Writing technical books is tough. Very tough. I have seen some of the Vegas books and they look pretty good. And, I really like the way Focal produced Tim Kolb's book on Premiere Pro. Great color pics. So maybe working with Focal will work out for you. |
Some additional history...
1 Attachment(s)
And for those folks who started editing after video became more common-place than film in corporate production, but long before the e=mc2, avid, cube, fcp, vegas, etc., it was also referred to as a "split-edit" on many machine controllers.
I won't give up my vegas, but it was fun to have a 286 computer with a full-control keyboard with jog/shuttle, running 4 BetaCamSP decks, an audio mixer and a video switcher all in sync. Well, at least they were usually in sync by the time their 5-second preroll was completed... I got pretty good at reading looooong printouts of timecode numbers. http://www.dvinfo.net/conf/attachmen...1&d=1168980821 |
2 Attachment(s)
Ty,
DSE covered this really well, but since you use FCP, I figured visuals from an actual FCP timeline might make things even clearer. These are shrunken screen grabs from my DVD series StartEditingNow - that I use to illustrate J-cuts and L-cuts. The basic point is that in a J-cut - the audio keeps rolling across the video edit. In an L-cut the video keeps rolling across an audio edit. Hope this helps. (from someone who, in my early days, always appreciated the virtues of over-explanation!) |
| All times are GMT -6. The time now is 05:42 PM. |
