Hollow echoing sound, can I fix? at DVinfo.net
All Things Audio
Old June 25th, 2007, 05:55 PM   #1
ive recorded some audio but it seems to sound a little hollow and it echos a fraction. Is there anything I can do to make it sound better?
I have Adobe soundbooth, premiere and after effects
--Canon XL1--
http://www.richardgrebby.co.uk
Richard Grebby is offline   Reply With Quote
Old June 25th, 2007, 07:32 PM   #2
Golden Rule No.1 : Get the microphone closer to the sound source.
Also, if indoors, don't record in a room with too many hard reflective surfaces. Use sound-deadening material such as blankets etc to cover walls and ceilings and floors as much as possible. Shotun mic designs particularly do not "react" well to reflective surfaces due to low-frequency's (particularly) bouncing off surfaces and inducing phase problems which can make mics sound hollow and unnatural.
Stu Holmes is offline   Reply With Quote
Old June 25th, 2007, 07:40 PM   #3
Since you have already broken the 'Golden Rule". EQ may help. Roll off 250 hz and boost 2.5 kHz on a graphic equalizer or parametric EQ.
Glenn Davidson is offline   Reply With Quote
Old June 26th, 2007, 07:25 AM   #4
Fred Retread
There is a method described by Bob Grant buried in another thread. Recorded echo such a common problem--most of us have slipped up on this at one time or another--that I decided to start a new thread with this as the main topic. I'm going to to that now.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply
