Is Digital Coax the same as S/PDIF? at DVinfo.net
All Things Audio
Old July 24th, 2007, 06:32 PM   #1
Hey guys.. I need to connect my two Edirol Studio Monitors with an S/PDIF cable and I have a digital coaxial cable here laying around. My question is:
Is a digital coaxial cable (package doesn't say anything about S/PDIF on it) the same as an S/PDIF cable?
Deke Ryland is offline   Reply With Quote
Old July 24th, 2007, 07:02 PM   #2
If I understand correctly, S/PDIF is what goes down the cable. You can use two types: coaxial or optical, so if your cable meets the S/PDIF specs then it should be fine, but I don't know what the specs are... I can't see any harm in trying.
Emre Safak is offline   Reply With Quote
Old July 25th, 2007, 04:47 AM   #3
S/PDIF specs call for 75 ohm unbalanced cabling which is the same cable as is commonly used for composite video. And FYI, AES/EBU specs call for 110 ohm balanced.
Old July 25th, 2007, 05:54 AM   #4
Shhhh! Don't tell anyone, but I've used short runs (1-2 feet) of high grade audio cable with RCAa on each end for S/PDIF.
Your cable should be OK.
Regards,
Ty Ford
Old July 25th, 2007, 09:21 AM   #5
While S/PDIF is a standard which includes details of the signalling i.e. bit rates, voltages, cable impedance (75 ohm) and type (unbalanced coaxial), coding ( bi-phase mark) frame markers, data bit assignments....) most coaxial cables sold for "digital audio", especially if for the consumer market, are intended for use with S/PDIF and are thus entirely suitable. As others have noted the cheapest piece of coax from Radio Shack, even though it be 50 Ohms and leak like a sieve may very well work just fine for short runs. That's the good news and bad news about digital. It either works or it doesn't.
Old July 27th, 2007, 10:26 PM   #6
I won't say a word - as long as you don't tell anybody that I've use LOW grade audio cables for about 3 ft without problems. (It was just a loop-back test.)
As said above, use a composite video cable - the ones with the yellow ends - to run within spec.
Jon Fairhurst
Old July 27th, 2007, 10:39 PM   #7
That's right, if they didn't want us using audio cables, why the RCA connector. Besides my 50 dollar Wydeeye Apogee gold plated 75 ohm digital s/pdif cable works like crap.
Glenn Davidson is offline   Reply With Quote
Old July 28th, 2007, 03:19 PM   #8
Originally Posted by Glenn Davidson View Post
...Besides my 50 dollar Wydeeye Apogee gold plated 75 ohm digital s/pdif cable works like crap.
How long is the run?
Jon Fairhurst
Old July 28th, 2007, 07:07 PM   #9
It's a short jumper. The problem is the design of the crimp on connectors. Both center pins are loose and do not make good contact.
Old July 29th, 2007, 02:52 PM   #10
You'd think the plug and jack manufacturers could figure out how to follow a 50 year old (?) spec by now!
Jon Fairhurst
Jon Fairhurst is offline   Reply
