AKG Blue Line vs. ULS series - Page 3 at DVinfo.net
All Things Audio
Old August 21st, 2007, 01:59 PM   #31
My AKG ULS C480B with the CK 63 just shipped. Still have to wait for the CK 69 though...
Can't wait to use it! :)
My movies:http://nl.youtube.com/user/somatichdg
-> Comments are welcome.
Hyun De Grande is offline   Reply With Quote
Old August 26th, 2007, 07:29 AM   #32
Originally Posted by Ty Ford View Post
Hello Pavel,
When operating without a good limiter (or mixer) it helps to set one level a bit lower. If someone screams, the louder track may distort, but hopefully the lower one won't.
Regards,
Ty Ford
Thank you.
Just to clarify...
I tried to adjust the volume but do not know how. I mean I plug 1 XLR mono mike into channel 1, select CH1, CH2 and the cursor is blinking on both tracks but I cannot adjust the channels individually since only 1 mike is plugged. It seems that the channel one is duplicated without the ability to be adjusted.
Please advice.
Thank you.
Pavel
Pavel Tomanec is offline   Reply With Quote
Old August 26th, 2007, 12:56 PM   #33
Hello Pavel,
I can only suggest that you refer to your users manual.
Regards,
Ty Ford
Old August 26th, 2007, 01:32 PM   #34
Pavel, I noticed you are using the Canon XH A1. When the option to copy audio channel 1 over to audio channel 2 is selected, all that happens is whatever level you've set for Ch.1 is duplicated to Ch.2, and there is no way to set a separate level for Ch.2 in this case.
By the way, this topic has been previously discussed in our Canon XH G1 / A1 forum. Hope this helps,
Old August 26th, 2007, 03:11 PM   #35
An XLR Y-cable will let you do this ... female to dual male (i.e. plugged into both XLR inputs on the camera). Turn phantom on for one channel.
Kris Bird is offline   Reply With Quote
Old August 31st, 2007, 01:28 PM   #36
Just received the CK69 and it's ridiculously big ! :p
Old September 5th, 2007, 04:54 AM   #37
Well I use that too (have the 480b + ck-69 + ck-63) its great but you can get away using only the first element. The extended tube on the ck69 makes it all long. But not heavy.
Not to forget to say: handling noise is the same on blueline or ULS. The shotgun ck-69 is way better sounding than the blueline, but for the hyper it's a close call. Love the -/+gain on the ULS though.
Raymond Toussaint is offline   Reply With Quote
Old September 5th, 2007, 06:30 AM   #38
The CK69 is designed to be used in both configurations. It can be either a long or short shot. AKG even publishes polar graphs for both. I would think you'd use the short shot most of the time.
Marco Leavitt is offline   Reply With Quote
Old September 7th, 2007, 08:57 AM   #39
I have a question regarding the CK 69 mics..:
I want to get a windjammer/-shield that would fit both the long and short gun, without buying two different sets.. So I guess I would have to look at some customizable ones..!? Which one(s) do you guys use?
Any advice ? Any recomendations?
Any brands I should look for? ..cause I have totally no clue !
Thanks in advance.
Old September 7th, 2007, 09:07 AM   #40
I'd go with a Rycote Softie for the long configuration. That's probably the cheapest way to do it.
Old September 7th, 2007, 07:27 PM   #41
I have a Reinhardt HW for the ck69 short that also fits (it eats the whole mic...) the small ck63 module. For the extention tube you need the longer Reinhardt but the weight is to much for daily use ON cam.I'm afraid you need to buy 2 sizes, although I need too.
BTW the Reinhard HW (high wind) works... but in almost normal windconditions, above you stil hear wind.
