Letus35 FLIP Module is now available at DVinfo.net
Alternative Imaging Methods
Old December 24th, 2007, 08:42 PM   #1
Hi all,
Team Letus is very pleased to announce the availability of our FLIP Module. This Flip module was built for those who own a third party upside-down adapter to get the image right side up. It features: * Highest optical grade achromatic lens custom-made for this specific module * Using prism with proprietary Image Orientation Correction technology (IOC) that makes the image up-right * Milled from solid aluminum * Comes with milled aluminum front and back caps match the module body * Alignment is a breeze with 72mm, 77mm or 82mm ring Notes: Currently, the FLIP Module works directly with SG Pro pre-flip adapter. Working with Brevis adapters will need a 62-to-72 step up ring. For M2 adapters, it needs entire different achromat which will be available on Jan 6th.
Thanks for your overwhelming support of our products.
Merry Christmas
Team Letus
http://www.adapterplace.com
Hien Le is offline   Reply With Quote
Old December 24th, 2007, 11:25 PM   #2
Would this be usable with my LetusXL to add more light? Or should I just wait until the release of the LetusXL Extreme?
-C
Old December 25th, 2007, 03:39 PM   #3
Wait a couple on months for the relay to go with the extreme.
Philip Bloom
Old December 26th, 2007, 12:32 PM   #4
This has big implications for a lot of us DIY builders..... I would like to see this tested on the the DIY Redrock like I built, or even on my lowly Letus35a. Has anybody at Letus used it with the 35a- footage ?
Chris J. Barcellos
Old December 27th, 2007, 07:11 PM   #5
i think the letus flip will work with the m2 when then get the right achromat for it in jan
Philip Bloom
Phil Bloom is offline   Reply
