Zacuto/Letus rig for big glass at DVinfo.net
Alternative Imaging Methods
Old July 23rd, 2008, 11:42 AM   #1
Hello,
I'd like to know how people are incorporating collar mount lenses with zacuto rails and the letus. I have a 80-200 2.8 lens and a 300 2.8 lens (both with collar mouths) I'd like to put on a letus, but I don't how to mount them on rails. And the studio rig from zacuto doesn't look to have long enough rails for the 80-200 and a matte box. I suppose I just substitute longer rails?
Can anyone give me some solutions?
James
James Sidney is offline   Reply With Quote
Old July 23rd, 2008, 04:26 PM   #2
There is a bit of a discussion about big lens use and adapters here.
http://www.dvinfo.net/conf/showthread.php?t=125608
To me, you will get better long lens capability on a normal zoom of most consumer cameras, so the benefit of using an adapter doesn't seem to be there for long lens work..
Chris J. Barcellos
Old July 23rd, 2008, 04:35 PM   #3
Thanks Chris, I have seen that thread. But really I'm interested in the very shallow depth of field of my 80-200 2.8 lens. Unfortunately it's a beast and needs to be supported via its mounting collar. Just need to know how to get a set of rails to accept it.
Surely this has been resolved by someone... Anyone?
Old July 23rd, 2008, 08:34 PM   #4
Its not a zacuto rig but it might give you an idea since its also an 80-200 f2.8 glass.
first attempt was just an angular aluminum support. screwed to the collar and just resting on top of the rails.
http://www.dvinfo.net/conf/showthread.php?t=113480
second version i had 2 alum angle bars riveted together and now screws to both collar and a rail block.
http://www.dvxuser6.com/uploaded/6699/1215617841.jpg
just like to point out that the slight arching is due to the fact i didnt lock the coupling for the fujinon thread to the adapter. its a solid and straight rig. measures 1 meter and 1cm exactly.
Old July 24th, 2008, 06:48 AM   #5
bara.... bara..... baracu..... u...... u...... dah!
Christopher Witz is offline   Reply With Quote
Old July 24th, 2008, 10:53 AM   #6
That's a heck of a rig...
I'm not very handy with home-made fixes. I need someone who manufactures the kind of adapter you have there. No third party out there?
Old July 25th, 2008, 12:02 AM   #7
Every now and again I link to this image. It might not be the biggest but it certainly is the ugliest.
http://www.dvinfo.net/media/hart/agusmto8.JPG
What looks like a rod support is actually the plastic corners of a case I had it resting on. To use it, I had a primitive pinewood support with a plate underneath with tripod screw tapped into it on the balance point.
Old July 30th, 2008, 04:06 PM   #8
Just noticed this on the Zacuto website: http://store.zacuto.com/product.php?productid=344
Spoke to a Zacuto salesperson and apparently it has vertical adjustment. I've ordered one, so will post my experiences when it arrives.
J
