I was wondering about the whole prism (rotate image) question. Doesn't the prism and mirror steal F-stops??
Because on the XL-1 you can simply flip the eyepiece to the other side and the image is corrected. Then in post you can just use the: http://www.leadtools.com/SDK/Multimedia/Direct-Show-Filters/Multimedia-DirectShow-Rotate.htm during capture (without loss I hope). If this is true then I would rather avoid bothering with prism and mirrors. Or am I wrong??? |
We can sell the relay lens for Euro 900,- (round $ 1.115,-)
We found a cheaper one, but i dont know how good it is. We check it next 2 weeks A mount adapter (to connect the lens to the Canon) cost Euro 198,- ( $ 245,- ) BTW: only with this lens (without the other GG adapter parts) you can make good night shoots. ( F stop = 0,95 ) Anders, yes, the prism "steal" a little bit light but. In F-stops? I think only 0,05. The prism is a expensive part, because you need a "big on" with inside more than 40mm diameter and it must be color corrected. I will check out the best price till next week Without the prism you need 10cm more distance. |
I don't understand why it needs to have 10 cm more distance!
In a normal still-camera the lens is only about 5 cm from the film... I can see that without the prism and mirror the light will travel a shorter distance but... I'm sure that you are correct but could you explain it to me? I would properly be interested in buying a colorcorrected prism then - So it would really like to know the best price you find. In the PDF file showing the PRO35 there is something called "Schutz glas" - Is that a fresnel?? Thanks |
schutzglas means protective glas
The way through a prism is longer than the prism outside. A still-camera have also build in a prism. So the way in a still-camera is also more then the outside dimensions.
But in different to the still-camera prism, you need a bigger one, because the relay lens have more than 30mm light circle. Thats why you need the big prism and thats why it take more distance. Okay, you can mount a macro lens in front of the relaylens to reduce the distance, but than you will have some distortions. The "SCHUTZ GLAS(S)" is only a clear glass to protect (SCHUTZ=protection) the inside parts for dust and dirt. To reduce (elimate) the hot spot there is a convex lens with the plan side very near behind the vibration GG (sorry last day i call this condenser, thats wrong) |
You say that the prism is expensive - what are talking here, $100 ? $500??????
Per member's requests, this thread has been merged with the Consolidated XL1 35mm Adapter thread -- this original copy is left intact for your viewing pleasure, but please direct all replies to the new monster we've created using the link above. Thanks,
| All times are GMT -6. The time now is 12:54 PM. |
