Problem with canon fd lens on 35mm adapter at DVinfo.net
Alternative Imaging Methods
Old September 2nd, 2009, 07:05 AM   #1
Good day there folks. I've got a little problem that just occured today and I think this is the right place to ask. I have a Jag35 adapter and until today I was using a Nikon 52mm 1,8 lens with no problems. Today I tried a Canon FD 50mm and noticed that although the focus ring works as expected, the F ring is not. Of course it turns normally but the iris won't open or close inside the lens. At the beginning I thought it's damaged but then I heard that you've got to attach it in a Canon camera that supports the lens in order to use it. This is a real problem. Is there any kind soul in this beautiful forum that knows a workaround that will allow me to use the F?
Dimitris Mantalias is offline   Reply With Quote
Old September 2nd, 2009, 09:53 AM   #2
There is a pin on the back of FD lenses that needs to be fixed into position with a bit of wire or broken off toothpick to enable manual aperture.
Wayne.
Wayne Kinney is offline   Reply With Quote
Old September 2nd, 2009, 10:55 AM   #3
Does the FD lens automatically default to wide open if you leave the pin alone?
Cris Hendrix is offline   Reply With Quote
Old September 11th, 2009, 03:59 AM   #4
Sorry for not replying, but I was getting married! Well, shame on me, the lens were going wide open when I was attaching them to the adaptor but were closing when I was taking it out. I could see that the image was OK when on, but I couldn't change the exposure. Still can't, but I don't mind now, since it's OK to have it all way open and change it through the camera iris wheel.
Thanks for your replies guys! :)
Old September 12th, 2009, 10:23 PM   #5
Yeah I probably should've updated that. I have two lenses, an older 35 with silver ring, and a newer 50 with the black ring. Didn't really care about adjusting stops just wanted both lenses wide open. The 35 was already wide open, but the 50 I had to use the two screwdrivers, turn the inside ring till it 'locked', adjust to f1.4, then unlock it and it stayed open when putting it on the mount - all good!
Old October 26th, 2009, 07:49 AM   #6
Images: 1
DOF at full open is pretty, but you're using the full diameter of the lens entrance so you'll get a very soft image and aberration. You will find you get a much nicer picture if you stop down; my magic number is f2.8.
BenWinter.com
Ben Winter is offline   Reply
