Can you tell what the difference is between these two lenses?
http://www.surplusshed.com/pages/item/l3034.html And http://www.surplusshed.com/pages/item/l1590.html (I think that is the one you bought Courtney ) One is a 53.6MM DIA. CTD ACHROMAT and the other 52MM SPOTTING SCOPE OBJECTIVE. Not sure what the difference is - maybe you might? |
They're both the same (except diameter size) except that one I got has a coating and the other one doesn't. If you're just buying one of these to mess with, to get your adapter set up - kind of a mock-up - or to see if it's going to work, it doesn't matter which you get. That's why I bought that one above. I just wanted to see how it was going to turn out. I have no intention on using that one specifically at all. Court |
| All times are GMT -6. The time now is 12:19 PM. |
