Is T3.5 different from F3.5? Should i expect translations in DOF? at DVinfo.net
Alternative Imaging Methods
Old February 14th, 2010, 02:05 AM   #1
Hey, what's up guys?
being off the field for a while.
Need some help here.
thank you very much in advance.
I want to know if there's any difference between let's say: T2.8 and F2.8
I notice the aperture in some lenses, such as the panavisions, comes expressed with a "T"
Is one or the other getting more light to the sensor,
so the DOF is different from one each other?
Roberto Lanczos is offline   Reply With Quote
Old February 14th, 2010, 02:23 AM   #2
*T* stops take the loss of light through the lens into account. F Stops are mathematical formulas that give an ideal best case. In other words, F Stop pretends there is no light loss through the glass, whereas T-Stops take the loss of the glass into account.
Old February 14th, 2010, 02:27 AM   #3
Is there a chart with equivalents of T-Stops to F-Stops ?
Old February 14th, 2010, 03:29 AM   #4
no, the whole point is that t-stops are calibrated to a given lens, where f-stops are, as Perrone says, simply mathematical and thus have more margin for error.
Just use the t-stops as you used to use f-stops and you will be fine.
Charles Papert
www.charlespapert.com
Charles Papert is offline   Reply
