Best 35mm adapter for sony hdr-fx1e at DVinfo.net
Alternative Imaging Methods
Old March 14th, 2006, 05:09 AM   #1
Hello everybody. I apologize if this has been asked many times before but I can't find the posts. :)
I would like to know what is the best 35mm adapter for my fx1. Of course it has to be cheap, like the letus35. I can't afford the P+S... :-P
Thanks very much, guys!
Daniele Napolitano is offline   Reply With Quote
Old March 14th, 2006, 05:27 AM   #2
The SGpro will be released next month, which will be ready to run with the FX-1.
Wayne.
Wayne Kinney is offline   Reply With Quote
Old March 14th, 2006, 06:03 AM   #3
Thanks for the reply.
Is the SGpro the only option?
Does the letus35 also work on the fx1?
Old March 14th, 2006, 06:06 AM   #4
Yes, the letus35 works with the FX-1.
Wayne.
Old March 14th, 2006, 11:40 AM   #5
Thanks for the reply!
In your opinion, which one works better?
Bye
Old March 14th, 2006, 12:19 PM   #6
Only users of the units can answer that.
Wayne.
Old March 14th, 2006, 12:36 PM   #7
Ok... so.. users, what are your impressions?
Thanks again!
Old March 14th, 2006, 12:51 PM   #8
i like my letus alot.. heres some impressive letus footage you might want to see
http://www.dvinfo.net/conf/showthread.php?t=59982
video : xl2 / letus35xl / bogen 503
photo- canon 1dmkII - bronica etrsi
Andrew Todd is offline   Reply With Quote
Old March 14th, 2006, 04:18 PM   #9
Ok... so what kind of lenses can you mount on the adapter? I found that the canon fd mount is not the same that the eos SLR series has (i'm planning on buying an eos 350d).
Do you recommend to use an adapter or to buy a fd compatible lens? What kind of lenses do you use, Andrew?
Sorry for my ignorance but I'm kind of new to this :)
Thanks!!
EDIT: I read that usign the adapter doesn't really work. Doesn't the letus 35 work with EF lenses?
And what kind of mount the SG35 has?
Thanks again!
Old March 15th, 2006, 10:16 AM   #10
In short yes, the fx1 will work with sg35. have tested it with the z1, which is the same thing.
Yasser Kassana is offline   Reply With Quote
Old March 15th, 2006, 10:28 AM   #11
Ok, good to know. But I was referring the sg35 lens mount, to which you attach the 35mm lens.
Old March 15th, 2006, 11:09 AM   #12
The SGpro will support Nikon or Canon FD lenses.
Wayne.
Old March 15th, 2006, 01:58 PM   #13
Thanks Wayne!
Old June 1st, 2006, 03:06 PM   #14
SG35 - I'm very happy with mind.
Since Wayne's modesty seems to be preventing him from tooting his own hor, let me do it. I am an SG35 owner; probably one of the first.
In short, I love it. There are a few minor problems, and it took longer to receive thatn I would have liked, but the overall operation is as promised, or better. It's a good design and a well constructed mechanism. Also, Wayne is very repsonsive to questions and problems.
For the record, I've read good things here about the Letus and Redrock 35 also.
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old June 1st, 2006, 09:47 PM   #15
Thanks! I actually already bought the sgpro and I'm waiting for it to arrive.
i've got great expectations! :)
bye!
