simplest, cheapest non vibrating gg 35mm at DVinfo.net
Alternative Imaging Methods
Old March 1st, 2007, 01:21 AM   #1
Hi all,
I've tried achieving the shallow depth of field look on my mini dv cam many times (using a Panasonic GS-400) and a while back looked at some plans for 35mm adapters. I'm not that handly... and building something with a motor, moving parts, and quite large is out of the question for me right now.
What I'm looking for is the easiest 35mm adapter to put onto my cam via step up rings, and extension tubes etc. I don't know what tutorial or plan to start with, and don't know if I need a macro feature or not on my cam, (it has a tele macro feature tho). Sorry don't know a lot of info about this stuff, and won't mind the grain that I've heard you get from not having the moving ground glass element.
Any links, advice, tutorials, or THE easy plan you can send my way?
Thanks all,
Luke
Luke McMillian is offline   Reply With Quote
Old March 1st, 2007, 01:32 AM   #2
go here, there is a tutorial on how to build one, you can get the parts you need from this site too.
http://www.jetsetmodels.info/news.htm
David Chia is offline   Reply With Quote
Old March 1st, 2007, 01:33 AM   #3
or here for a rotating gg
http://www.mediachance.com/dvdlab/dof/index.htm
Old March 1st, 2007, 01:43 AM   #4
There is also one more here. It looks good and easy but there are two UV filters inside that might be causing some flare/internal reflections
http://www.dvxuser.com/V6/showthread.php?t=45972
Old March 1st, 2007, 02:22 AM   #5
The simplest way to construct a DOF adaptor.
The simplest way to construct a non-moving DOF adaptor for smaller camcorders like GS400:
Screw a Nikon BR-3 to Thorlabs SM2L30
Then screw in the included retaining ring to match approximate lens mount to GG distance then throw in a static GG holder for Thorlabs 2" tubes from Daniel or from me, attach a Canon EE-A focusing screen (about 0% light loss) to it and then fix it with additional retaining ring from Thorlabs (SM2R2), then add the Thorlabs coupler (SM2T2) and add a 42mm to 52mm step up ring to your camcorder to attach the adaptor assembly.
Fine tune the GG to lens mount distance by screwing the retaining rings. Retaining rings can be adjusted with special spanner wrench or with precision philips screw driver.
It will take some three minutes and no glueing or drilling or what so ever plus everything is adjustable, just make sure you dont scratch the GG in progres.
Buy a can of compressed air to get rid of the occasional dust appearing on the GG.
This is not the cheapest way (around $150) to construct a DOF adaptor but by far the most fool proof and good looking.
Cheers,
T
Toenis Liivamaegi is offline   Reply
