sony sr 10 sd mode at DVinfo.net
AVCHD Format Discussion
Old December 15th, 2008, 12:06 PM   #1
sony sr 10 sd mode
...not that one would often ... but anyone ever use the sd mode on this or a similar sony avchd model and how was the quality? ... i was not real impressed with the quality of the sr65 hard drive (sr65 only sd not a hd camera...)
Matthew Harris is offline   Reply With Quote
Old December 16th, 2008, 06:08 AM   #2
Having done a resolution test with my SR 12 in all 4 modes and useing different angle and general shots including small bare tree branches i could see no difference at all on my 50" pioneer through hdmi or component inputs, this surprised me as i have always used FH and will probobly continue to but it does make you think,of note moving cars looked the same as well.
Martyn Hull is offline   Reply With Quote
Old December 16th, 2008, 02:21 PM   #3
The SR11/12 have 4 modes in HD and 3 modes in SD. There is quite a difference between the highest data rate in HD and the lowest in SD. I expect the SR10 is similar but with a less capable imager only 1/5" rather than 1/3"
Ron Evans
Ron Evans is offline   Reply
