-   AVCHD Format Discussion (https://www.dvinfo.net/forum/avchd-format-discussion/)
-   -   Telephoto lenses for SR11? (https://www.dvinfo.net/forum/avchd-format-discussion/234866-telephoto-lenses-sr11.html)
Mike Burgess May 7th, 2009 08:40 AM
OK one more question! After conducting a search on this forum, I have not found what I am looking for (perhaps I am too impatient).
What is a good telephoto lens for the SR11? Is the Sony VCL-HG1737C a good lense? Anything better? I will be on vacation in four weeks (heading out west) and want a good lense that won't degrade my video quality for when I later produce AVCHD footage on a DVD.
Thanks.
Mike
Robin Davies-Rollinson May 7th, 2009 04:13 PM
Mike,
I don't know about the Sony lens, but I've just bought the Canon TL-H37 37mm 1.5X Tele Converter for my HF10.
It's very very good...
Just make sure that you use it with a good steady tripod though!
Mike Burgess May 7th, 2009 05:57 PM
Hi Robin. Yes, I use a tripod the majority of the time. Does your lens show any black ring around the outside of the scene when it is zoomed back?
Mike
Robin Davies-Rollinson May 8th, 2009 12:04 AM
Yes it does - there is vignetting at the widest setting - but I don't need to come out too wide, since there's still plenty of variation before having to take it off to go back to the internal lens.
Mike Burgess May 8th, 2009 12:13 PM
Bummer.
Are there any telephoto lenses out there that have a lesser problem with viginetting?
Pavel Houda May 8th, 2009 07:51 PM
Raynox has a couple of excellent converters for SR-11 : Raynox High Definition Conversion Lens Accessories for SONY HDR-SR11, HDR-SR12 AVCHD Camcorders
J. Stephen McDonald May 8th, 2009 08:04 PM
I have the Raynox HD-2200, that I use on my HC9 and some still cameras. It is very sharp and shows no distortion at the edges. It causes vignetting below 60% zoom on the HC9.
They now sell a slightly different model number, but it's the same lens with an alternate collection of step-rings.
Mike Burgess May 9th, 2009 08:09 AM
Is it safe for me to assume that all telephoto lenses suffer from vignetting when one zooms back?
Mike
Dave Blackhurst May 9th, 2009 09:10 PM
yup... the only way I can think of to avoid it might be to get a substantially larger diameter lens and use a stepdown ring, not even sure that would eliminate the problem entirely.
J. Stephen McDonald May 9th, 2009 09:45 PM
Sony VCL-DH1774 Telextender?
If you wanted to spend about $130. and experiment with a Sony VCL-DH1774 telextender, you might be able to avoid all or almost all vignetting on a camcorder with a 37mm mounting thread. Pemaraal sells a 58mm to 74mm step-up ring and you can get a 37mm to 58mm step-up ring at B&H. You'd need them both. The DH1774 is designed for Sony digital still cameras and has very sharp resolution. It's a real bargain for its price and you could use it on larger cameras and camcorders, with the right step-rings. It gives 1.7X magnification. I use its smaller relative on my HC9, the DH1758, where it vignettes below 60% zoom.
Mike Burgess May 10th, 2009 07:34 AM
Thanks, I was afraid of that. As for the step up rings, I will give that some thought. In your opinions, is the DH1758 a better lens than the Sony HG1737C?
Thanks again.
Mike
J. Stephen McDonald May 10th, 2009 06:28 PM
Thanks again.
Mike
Mike, I haven't used the Sony HG1737C, but I imagine that it is comparable in optical quality to the DH1758, except that the latter is larger. Since the DH1758 was originally designed to fit digital photo cameras, with 6-MP or 7-MP sensors, its resolution level is plenty high enough for HD video. From my comparisons with the Raynox DCR-2020PRO, a 2.2X telex with a 260 line per mm. resolution, I estimate the DH1758 to have at least a 220 line per mm. capability. As I mentioned, a 37mm to 58mm step-up ring is stocked at B&H.
I've used the DH1758 on my HC9 for about 2/3 of all my shooting of wildlife and other long-range subjects. Since it vignettes only below 30% zoom, it is practical to leave it on the camcorder most of the time. I also use it on my Canon S5 photo camera and plan to put it on a Sony HX1, with my own fiberglass lens adaptor tube.
I'm now also using a small Raynox HD-2200 telex, which is working very well on the HC9, giving 2.2X, but it vignettes below 60% zoom. Users of the large DH1774 Sony telex, say it's at least as sharp as the DH1758. The DH1774 might work on one of the larger HD camcorders that have 72mm mounting threads, with a 72mm to 74mm step-up ring, that can be found at one of the places I mentioned in the previous message. With both the DH1758 and HD-2200, the autofocus on my HC9 works fine. Good luck in finding the right lens.
Rob Croll May 15th, 2009 06:40 AM
As I understand it the Sony 1.7x is the only one that Sony recommends. So if you buy it and it doesn't work brilliantly, you're well within your rights to return it.
If you do buy it, I'd be very interested in what you views. I like filming surfing and the 10x almost gets me there. I'm happy using digital zoom but the 1.7x adapter would definitely do the trick.
I think there is a setting in the camera you need to change when the 1.7x is being used
Mike Burgess May 16th, 2009 06:44 AM
I just got the Sony lens yesterday, and today it is raining. As soon as the weather cooperates, I will take the cam and lens out to the Lake Michigan shoreline and give it all a try. I will then let you know my impressions.
Mike
Mike Burgess May 29th, 2009 03:38 PM
Two weeks later and I still have not tested the new lens. Hopefully will yet this weekend. Is there anything I should know as far as differences in settings that the camcorder should be set at?
Mike
Tom Cadwalader May 29th, 2009 07:39 PM
Camera Setting
Mike,
There is a setting that can be used when a conversion lens is installed. It is found under... Home....movie settings then on the last page (4/4) is Conversion lens. Under this button is Tele Conversion, Wide Conversion and Off. What it does, as I understand it, is that it matches the Steady Shot level to the lens being used. So if you are on a tripod it might not matter.
I found a good way to test the lens is to shoot across the water to an island or point of land that is a few miles away. If the lens is good, the whole line of tress will be sharp. If the edges are blurred, not so good. My 1.5 Tokina did not fair well shooting at Bois Blanc Island from about 5 miles away.
I am very interested in how your Sony fares.
Mike Burgess May 30th, 2009 10:06 AM
Thanks Tom. I will be going out later this weekend if the weather cooperates, to test things out. I will report back then. Need to get this all smoothed out before I head out west on vacation.
Mike
