Sanyo Xacti HD1010 - Format confusion AHOY ! at DVinfo.net
AVCHD Format Discussion
Old June 15th, 2009, 04:48 AM   #1
Hey guys, just very confused with this little camera as the manual isn't really telling me everything I need to know for editing formats.
When I set the camera to record in 'Full HD' it does so as: 1920 × 1080 pixels, 60 field/s
* The 60 fps frame rate of this camera is 59.94 fps
So if I were to edit that footage as it is, I'd need to set a project up as 1920x1080 at 59.94fps - However, how am I to know if that is interlaced or not ?
Also I can't see the advantage of shooting at 59.94fps, I just set it as that initially as it was at the top, and didn't have time to test before shooting, 30p would be more ideal, as I can then convert that to 25p easily.
Rob O'Day is offline   Reply With Quote
Old June 21st, 2009, 09:09 PM   #2
Without actually checking the specs, the normal wording is that 60 fields per second means it is interlaced. They would say 60 frames per second if it were progressive (i.e. non-interlaced).
Depending on the method you use to convert to 25P, you will likely get a better result converting from 60i than from 30P, since there is more temporal info for the conversion to work with.
Old July 7th, 2009, 10:59 AM   #3
Ahh, ok.
IT's a bit annoying that they aren't more specific, as it's not like editing that footage is as straight forwards as trusty old mini dv was !
I'm also just wondering why it's not fully 60fps but instead 59.94fps ?
Old July 7th, 2009, 11:26 AM   #4
59.94 is double the 29.97 frames per sec NTSC broadcast framerate (i.e., two fields for each full frame)
Old July 7th, 2009, 11:43 AM   #5
Thank you.
Hopefully I can find a good solution to this, as I just want 25p to work with :D
Old July 9th, 2009, 02:55 PM   #6
Some cameras like the Canons are wrapping 24fps in 60i, you have to deinterlace the footage using something like cineform or voltaichd
Cris Hendrix is offline   Reply
