Importing AVCHD at DVinfo.net
AVCHD Format Discussion
Old January 24th, 2012, 07:03 AM   #1
Importing AVCHD
The client filmed an event with me using his consumer video camera. He mailed me the SD cards but I don't know how to import the footage. Btw, I'm using a FCP6 on a Mac.
Edit: Nevermind figured it out "Log and Transfer"
Old January 25th, 2012, 03:51 PM   #2
Re: Importing AVCHD
Just to add, for your info. Log and Transfer transcodes (converts) original files into Apple's 422 ProRes format, which is much easier for your Mac to handle, but takes up inordinate amount of space.
If you:
1. Have a very powerful Mac;
2. Are constrained for space;
3. Feel the need to eliminate any possible generational image quality loss due to conversion (even if you can't see it),
then you may also want to look into 'Clipwrap', an application that takes the original AVCHD files and just changes the 'wrapper' (small portion of each file) to make it a plain vanila QuickTime file, which FCP can read directly. You get to work with the original video data (rather than a converted copy), but your Mac gets to do much more heavy lifting. Trial is free (re-wraps only first minute of each file); full version is $50.
Predrag Vasic is offline   Reply
