Continuous AVCHD Playback on PC at DVinfo.net
AVCHD Format Discussion
Old April 19th, 2015, 07:00 PM   #1
A very simple requirement !! - Is there any software out there that will simply AND continuously, play back AVCHD files from a folder in a PC. It is a pain having to play each clip separately when reviewing these clips prior to importing them into the editor.
I don't understand why this has not been addressed before, as cameras & editors play them this way why can't Windows ??
RonC.
Ron Cooper is offline   Reply With Quote
Old April 19th, 2015, 08:33 PM   #2
Re: Continuous AVCHD Playback on PC
VLC media player can do that. Load up a folder of files in the play list and bam. It will play them all and even repeat the list if you like.
http://www.LandYachtMedia.com
Old April 20th, 2015, 12:20 AM   #3
Thanks Chris. - I downloaded VLC and it is a big improvement on the last time I tried it but there is still a distint gap between files.
I cannot understand all this as these files play so smoothly in-camera. Surely there is a reason.
How do simple cameras manage to handle it so smoothly ? - What software/codecs do they use ?
Regards,
RonC.
Old April 20th, 2015, 05:42 AM   #4
VLC will play continuously but it sounds like you are wanting seamless playback. Is that right?
Old April 21st, 2015, 12:02 AM   #5
Thanks again Chris, - yes, certainly, just like the cameras do.
RonC.
Old April 21st, 2015, 07:25 AM   #6
What NLE do you use? With Premiere, if you simply use File > Import with spanned clips, they will have the gap/glitch between them. The trick is to copy entire SD card contents to hard drive - all folders intact - and then use "Media Browser" within Premiere to do the import. Multiple spanned clips will then import as one single long clip, glitch free.
Jeff Pulera
Safe Harbor Computers
Old April 22nd, 2015, 07:40 PM   #7
Thank you Jeff.
No, I don't use Premiere, I use Vegas, but really all I was hoping for is a simple way of playing these files just from windows or a simple program without having to put them into an editor first.
Sure, I can import them into Vegas & drop them straight on the time line & they play seemlessly but I just want a simple way of just highlighting a few files and then able to quickly show my efforts to others watching on my computer. Just like I used to do with AVI files.
RonC.
Old April 23rd, 2015, 03:46 PM   #8
RonC.
Hi Ron,
Windows can. What version are you running?
On my PC running Windows 7 Pro, all I do is migrate to the folder containing the AVCHD clips using Windows Explorer. There is a bar along the top of the window with several choices. Just select the choice "Play all" and Windows Media Player plays all the clips in the folder, one after another, until all are finished. Then WMP asks if you want to play them again. Yes, there is a VERY brief, fraction of a second pause between clips. Length of pause may depend on speed of the PC. Mines is an I7 from 2009.
The list of choices in the bar: Organize, Include in library, Share with, Play all, Burn, New Folder
It also works with audio files. For Pictures "Play all" choice is replaced with "Slide show"
If you don't want to play all the clips in the folder, it requires a few mouse clicks. Left click the first clip while holding down the shift key. Left click the last clip while continuing to hold the shift key. Then Right click, still holding the shift key, and select PLAY from the menu that opens up.
Another variation is to hold the control key and select individual clips while holding the control key. Then right click and select play.
Hope this helps.
Roger
Roger
My YouTube Channel: https://www.youtube.com/channel/UCAp...2AHr_pHFID5LDA
Last edited by Roger Van Duyn; April 23rd, 2015 at 04:01 PM. Reason: pause issue, play only selected clip.
Roger Van Duyn is offline   Reply With Quote
Old April 23rd, 2015, 04:55 PM   #9
Many thanks Roger.
My lovely win 7 machine crashed & at present I'm on a dreaded Win 8 - (aarrrgghh !! ) a powerful laptop but it was sort of doing what you described but I'm pushed for time, but it did look as if I had to import the files into a playlist first, but I will check again later.
RonC.
Old April 24th, 2015, 07:44 AM   #10
I feel your pain. I spent part of yesterday helping a client fight with his Win8 machine. Did not enjoy the experience. Mousing around was clunky. Keyboard commands, control C, control v, etc. still seem to work the old fashioned way, and that's what I did. Didn't have time to teach those commands to the client because had to run to another appointment.
From that experience, it seems to me Microsoft leaves out some codecs it used to include.
My son's PC running the latest version of 8 is better, but his machine has been customized.
Roger
Old April 27th, 2015, 01:08 AM   #11
Thanks again Roger, - still haven't time to really check out all your suggestions but I am running the Latest Win 8.1 if that helps.
You are probably correct about Microsoft leaving things off, as I am suffering other major problems with lost emails & other VIP stuff. - On Win 7, I was using Outlook Express & even had many folders & files backed up on another drive, but now I find that Win 8.1 only has M/S Outlook, which won't even read these files. - Bizarre !
RonC.
