Avid Liquid to Final Cut at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old June 23rd, 2008, 01:53 PM   #1
How do I import clips from Avid Liquid 7.2 to Final Cut Pro 6.0.3. I have tried to just make the clips Quicktime files but FC will not read the files. What am i missing?
Paul Cronin
www.paulcroninstudios.com
Old June 23rd, 2008, 02:32 PM   #2
I'm not sure what type of files you are dealing with (DV, HDV, Uncompressed???)...but, it would probably be better to export from Liquid as an uncompressed AVI file.
Jim Boda is offline   Reply With Quote
Old June 23rd, 2008, 02:50 PM   #3
Hi Jim,
They are HDV files some are 1080i from a Z1 and some are 30F from a Canon A1. So I think AVI is all SD correct?
Paul Cronin
Old June 23rd, 2008, 03:47 PM   #4
Hi Jim,
The AVI resolution could be set to 1440 X 1080i...but, the file size would be dramatically larger.
Why not just stay with the HDV2 format?
Export from Liquid as an MPEG-2--- Select HDV2 1080i
Then import to FCP on an HDV2 (1440 x 1080i) timeline.
Old June 24th, 2008, 09:01 AM   #5
Thank Jim I will give this a try again and double check my settings to see if it will work this time.
Paul Cronin
Old June 24th, 2008, 02:58 PM   #6
Thanks Jim I will give this a try again and double check my settings to see if it will work this time.
Yea, the Quicktime export should translate. However, you need to set a preset that matches the resolution and interlacing of the HDV2 codec. I normally use one of the BlackMagic codecs for exporting to QT...but, for HDV2 I would probably export w/ the standard MPEG2 HDV2 settings.
And from there, FCP should add the QT wrapper on the files.
Old July 19th, 2008, 11:34 AM   #7
Well I finally had time to switch the clips from the PC (Avid Liquid 7.2) to Final Cut Pro 6.0.4.
I saved the files as MPEG 2 1080i then imported into FC as files. Now the weird part is it will only play smooth at HDV 1080P 30 which is fine with me.
Thanks for the help.
Paul Cronin
Paul Cronin is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
