Which settings in Toast 10 for Bluray burning? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Blu-Ray Authoring
Old January 24th, 2010, 07:51 AM   #1
I have to burn a Bluray disk of a Quicktime Movie in ProRes422, 25 progressive, 35 megabit variable bit rate. The disk will be played on a Panasonic Bluray player and shown on a LCD-flatscreen, true 25p and full HD. Could anyone tell me what are the best suited coded settings in Toast 10? I'm looking for the best image quality with no artefacts.
Old January 24th, 2010, 08:06 AM   #2
How long is the QT movie?
Martin at HeadSpin HD on Blu-ray
Martin Mayer is offline   Reply With Quote
Old January 24th, 2010, 12:04 PM   #3
Well, actually there are two movies: one of 10 minutes and one of 32 minutes. They can be burnt on two separate disks.
Old January 24th, 2010, 12:07 PM   #4
Well, you could put both those movies on one single-sided 25GB Blu-ray Disc at the maximum bit-rate = 26Mbps (with a lot of room to spare).
You can't go higher than that bitrate, as that would be outside the BD spec, and a set-top player would choke. Toast will have to re-encode your super-quality original, but I don't think you'll be disappointed with the quality at 26Mbps.
Old January 24th, 2010, 12:55 PM   #5
OK, Martin, I'll choose 'custom' and take the maximum bitrate: 26 Mbit/sec
How should the other settings in that pane be, ideally? :
- Format: MPEG 4 AVC, I presume?
- Re-encoding: 'automatic', 'always' or 'never'?
- Field dominance: 'Automatic', 'Top field first', 'Bottom field first' or 'progressive'? I remember I tried 'progressive' before and got a lot of 'combing' artefacts when panning.
Luc
Old January 25th, 2010, 05:52 PM   #6
Yes, MPEG4 AVC.
And I would leave the others all on Auto, and carefully view the results on a set-top DVD player connected by HDMI to an HD-Ready TV.
I would be worried that you shot in 25p - as I personally don't like 25p at all - but that's just me. I shoot 50i and prefer the smooth motion.
Frankly, if you get artefacts on vertical edges when slow panning, that's what I would expect from 25p. Why DID you shoot 25p in the first place??!!
Old January 26th, 2010, 02:50 AM   #7
Well, mostly because I'm only viewing my movies on apparatuses that build up their image in a purely progressive way, like plasma and LCD-flatscreens. I tried interlaced before and had lots of de-interlacing artefacts. Most people on this forum also advise progressive, so I trusted their advice...
Old January 27th, 2010, 03:39 AM   #8
Originally Posted by Martin Mayer View Post
Yes, MPEG4 AVC.
Martin,
I did some testing with interlaced yesterday and as you point out, even fast pans are perfectly smooth. Guess I'll have to reconsider my 25p habit... Although the result looked a little less sharp.
Luc De Wandel is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Blu-Ray Authoring
