EOS Custom Picture File at DVinfo.net
Old January 29th, 2012, 01:11 PM   #1
Telecam Films
In the C300 op manual, the C8 EOS Std custom picture file is described as such:
"Reproduces the image quality and look (high contrast, vibrant colors) of an EOS digital SLR camera with its picture style set to [Standard]."
which means that inter-cutting C300 footage shot with this profile with Canon 5D/7D should be seamless. Can anyone confirm that it is indeed the case?
Thanks.
Thierry Humeau, DoP
Télécam Films
www.telecamfilms.com
Thierry Humeau is offline   Reply With Quote
Old January 29th, 2012, 02:44 PM   #2
Re: EOS Custom Picture File
But who shoots with the 5d at standard settings? Doesn't everyone dial all the contrast and sharpness settings completely down and use the Neutral profile?
Mikko Topponen is offline   Reply With Quote
Old January 29th, 2012, 05:52 PM   #3
At least! It's that or Cinestyle for me 100% of the time on Canon DSLRs.
Kevin Dooley
Media Director, Pantego Bible Church
Kevin Dooley is offline   Reply With Quote
Old January 29th, 2012, 08:16 PM   #4
Telecam Films
We all make tweaks to 5D scene files but overall, I just want to see a confirmation that when using EOS picture profile, the C300 inter-cuts seamlessly with 5D/7D footage. I think a C300/5D combo could be very handy.
Thanks.
Thierry Humeau, DoP
Télécam Films
Old January 29th, 2012, 08:58 PM   #5
I highly doubt it will be "seamless"
I own a c300, and ive looked at the EOS setting and it does look similar to a 5d, but not quite the same.
Colin McAuliffe is offline   Reply With Quote
Old January 30th, 2012, 12:16 PM   #6
Telecam Films
Would you say it looks better or not as good as a 5D? I like the words "high contrast, vibrant colors" they use to describe the EOS picture profile because regardless of the 5D downsides, these are what catches the viewers attention. I hope the EOS picture profile can emulate this or come close enough.
Take care,
T.
Thierry Humeau, DoP
Télécam Films
Old February 4th, 2012, 02:00 PM   #7
High contrast and vibrant colors are generally pretty easy to achieve with color correction--the trick is going back the other way, especially with contrast. Shooting in a contrasty situation to begin with, it's much better to capture a wider flat range of values and build the contrast back in later so you can dial in the shadow or highlight detail as required. It's nice to have that option, especially if one is delivering footage that won't go through a CC process.
Charles Papert
www.charlespapert.com
Old February 4th, 2012, 07:11 PM   #8
Telecam Films
Charles,
I understand that. My original question was to whether or not, the EOS profile on the C300 matches the Standard profile on a 5D. That is it.
Best,
Thierry Humeau, DoP
Télécam Films
