C100: Premiere CS6 Sequence settings at DVinfo.net
Old December 31st, 2012, 02:07 PM   #1
I'm using the using the 'AVCHD 1080p30' setting but its asking to keep existing or modify. I select modify and then looking at the interpret fields, Upper is selected, surely it should be progressive?
Dan Burnap is offline   Reply With Quote
Old December 31st, 2012, 02:56 PM   #2
Re: C100: Premiere CS6 Sequence settings
Try dragging the video file in the project window down to the "new item" icon (looks like a post-it-note, next to the new folder icon). This should create a new sequence with the exact settings of the footage.
Andrew Bove is offline   Reply With Quote
Old December 31st, 2012, 06:16 PM   #3
As I recall the C100 doesn't produce true progressive as such, it's within an interlaced wrapper.
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply With Quote
Old January 1st, 2013, 11:00 AM   #4
Here is how you do it.
Adobe Community: Canon C100 AVCHD workflow
And also this is essential reading to gen up on PsF and CS 5.5.2 workflow.
http://provideocoalition.com/atepper...e_pro_cs5.5.x/
Andy Wilkinson is offline   Reply
