Canon 35MM T1.5 Cinema Prime $5200 ETA Dec 2013 - Page 2 at DVinfo.net
Old December 13th, 2013, 03:39 PM   #16
Re: Canon 35MM T1.5 Cinema Prime $5200 ETA Dec 2013
Originally Posted by Terry Nixon View Post
Hi Barry,
from what i've read the Cinema Prime lenses are not the same lenses at the L series glass.
Terry
Hey... I'm not crazy:-)
From FotoCare's website (and a dozen others selling the CN-E lenses, indicating the language came from Canon)
The Canon CN-E 50mm T1.3 L F Cine Lens is a 50mm fixed focal length lens designed for cine-applications. It comes in Canon's EF mount and is for use with Canon's EOS C300 and with full-frame EOS DSLRs. The lens is based on Canon's EF 50mm f/1.2L and is optimized for cine-use with upgraded optics and coating and a completely redesigned mechanical construction.
and
The Canon CN-E 24mm T1.5 L F Cine Lens is a 24mm wide-angle fixed focal length lens designed for cine-applications. It comes in Canon's EF mount and is for use with Canon's EOS C300 and with full-frame EOS DSLRs. The lens is based on Canon's EF 24mm f/1.4L II and is optimized for cine-use with upgraded optics and coating and a completely redesigned mechanical construction.
and
The Canon CN-E 85mm T1.3 L F Cine Lens is an 85mm fixed focal length lens designed for cine-applications and capable of telephoto "looks". It comes in Canon's EF mount and is for use with Canon's EOS C300 and with full-frame EOS DSLRs.
The lens is based on Canon's EF 85mm f/1.2L II USM and is optimized for cine-use with upgraded optics and coating and a completely redesigned mechanical construction.
Barry Goyette is offline   Reply
