7D shaky footage resolved at DVinfo.net
Canon EOS Crop Sensor for HD
Old September 27th, 2009, 05:24 PM   #1
SWB from another forum had the simple but effective answer..."World's cheapest hand-held stabilizer: put the camera strap around your neck and hold out your arms until the strap goes taut. I shot plenty of silky smooth D90 footage with this technique."
Sounds simple but the difference is night and day.
Neil Dankoff is offline   Reply With Quote
Old September 27th, 2009, 05:48 PM   #2
Nearly as cheap: Take a 1/4"-20 threaded eye bolt + a matching wing nut + a piece of string, say 6 or 7 feet long. Total cost @ Home dept: $0.42. Put wing nut on bolt, tie one end of the string to bolt eye. Keep the whole thing in in your pocket when not using it.
To use: Screw bolt into tripod socket, tighten with wing nut. Raise camera to shooting height, step on string to keep it taut. Pull UP on the camera to stabilize....
Kevin Bjorke is offline   Reply With Quote
Old September 27th, 2009, 06:53 PM   #3
Variant: the neck strap around the neck and a Magic Arm under the cam, pressed on the waist. Rock steady.
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply
