Final Cut Pro workflow suggestions? at DVinfo.net
Canon EOS Crop Sensor for HD
Old August 27th, 2010, 10:30 AM   #1
I'd love to hear your workflow or see links to good, thorough tutorials for taking footage from a 7D and into/out of Final Cut. I know there are so many variables, but I just need to beef up on what's out there. I currently use mpeg streamclip and convert footage using the DVCPRO 720p codec. But with the release of Canon's new plug-in to FCP, I'm wondering if that means I can skip the mpeg streamclip step.
Also, correct me on this if I'm wrong: Standard DVDs can only handle SD video, or 720x480. To burn an HD video to DVD, I'd have to have a Blu-Ray burner on my computer and Blu-Ray DVD-Rs. Is that true?
David Lavender is offline   Reply With Quote
Old August 27th, 2010, 11:20 AM   #2
Just one word (maybe two) - ProRes.
There is already a thread on the FCP Canon plug-in, so I'm not going into that. I convert all my stuff - 7D (H.264) and EXDCAM to ProRes. Yes you can continue to use mpeg streamclip to convert 7D footage to ProRes or you can do this within Final Cut.
You can put anything on a DVD - but a single layer DVD will take very little HD - up to about 4.5Gig (4.7 officially) or use a double layer - DVD 9, but regular DVD players may not recognize the HD format.
BluRay will need also need Blu-Ray authoring software - such as Roxio Toast beside the burner and yes, BR discs.
Jon Braeley is offline   Reply With Quote
Old August 27th, 2010, 11:25 AM   #3
Contributor
What I do is:
-Copy all my original to a USB drive.
-Transcode that to ProRes422 with MPEG Streamclip, and send it to a firewire drive.
-Burn Blu-ray discs of all my original.
I keep the Blu-rays filed away as I did tape.
The steps are simple but keeping organized is essential. For my original footage I make one folder for it all. Within that folder I usually have separate folders by location. Then within each of those, I have a folder for video clips and one for audio clips if there's sync sound involved. I'll label all the sync video accordingly and keep it separate from non-sync. Easier to find that way when I start syncing clips.
I make corresponding folders in the firewire drives for all the 422 conversions. The audio files go to the firewire drives too. So the USB houses all the original, the firewire drives get all the ProRes 422. And the Blu-rays store the original in case the USB drive dies. I thought about keeping the ProRes backed up, but I'd rather keep the original. For example if I someday wanted ProRes444 for some reason, I could always go back to the original. Or if I wanted to send the original to somebody who used Avid, etc. Lots of reasons to keep the original in its original form.
Yes, DVDs are SD. You want to author Blu-ray discs, you need a Blu-ray burner.
Why are you going to 720p instead of keeping it all 1080p?
Old August 29th, 2010, 03:37 PM   #4
I use Compressor or FCP to convert to ProRes not Mpeg Streamclip.
I have to check on my version, but using Streamclip you cannot set field dominance to 'none' - the only choice is upper or lower which are both wrong for ProRes which use none.
If I use Compressor then field dominance is ignored - same with FCP, which is as it should be.
Old August 29th, 2010, 07:17 PM   #5
Sponsor: Westside AV
I just drag all the clips into FCP then decide what clips or part thereof I want to use. And then export those as Prores. Then I actually do all my work in M100. But you could reimport into FCP just as well.
I often have 5 or more takes of the same shot, why waste the time converting bad shots, when I know I will not use them.
This approach is similar to the old days of digitizing tapes. I never digitized all of them. You can always go back quickly and convert more clips if you find you need them. Much faster than setting up tape digitizing.
I archive the original h.264 clips on FW800 HD's and Bluray DVDs. This saves time and space, and works well for me. I do something very similar with XDcam footage. That is only convert what I really need. But archive all the footage in the original format. All the footage also gets entered in a searchable database.
I work on a lot of projects with hundreds of hours of footage. It does not make sense to me to convert it all on long form projects.
But projects with only an hour or so worth of footage I usually convert all the clips, RAIDs are pretty cheap these days.
Old August 30th, 2010, 06:39 AM   #6
I just assumed that of course you would not convert ALL your 7D footage.
But you dont need to import them into FCP, where H264 will play horribly anyway - just click on the them and view them in QT player that's what I do.
Old August 30th, 2010, 06:57 AM   #7
It depends on your computer and RAID speed. On my 8core with raid the h.264 plays fine in FCP. And it is easier to export small chunks of clips in FCP than QT, that is why I use FCP. I can also have lots of clips open at the same time and easily decide on the best out of 10 takes or so, I can write comments for each take etc.
I also always keep all the FCP projects together with the archived clips so I can easily go back and see my comments years later.
Just my way of doing it.
Old August 30th, 2010, 01:35 PM   #8
Contributor
"I have to check on my version, but using Streamclip you cannot set field dominance to 'none' - the only choice is upper or lower which are both wrong for ProRes which use none.
If I use Compressor then field dominance is ignored - same with FCP, which is as it should be."
With MPEG Streamclip you simply make sure "deinterlace" is de-selected. No need to change field dominance to anything since there isn't any in progressive frames.
Old August 30th, 2010, 01:46 PM   #9
As above, streamclip works just fine as long as it knows you're dealing with progressive footage. Been using it since I got my t2i. Compressors just too slow.
Old October 25th, 2010, 09:34 PM   #10
Can anyone tell me what the best Blu-Ray authoring software is for use with FCP on a Mac please?
Candid female wedding videographers in Sydney, Australia
www.harbourcityfilms.com.au
Rachael Hastie is offline   Reply With Quote
Old October 26th, 2010, 11:11 AM   #11
Hi there,
David,
This is what I do.
I have a 7D with an iMac Core 5 and FCP.
I download my clips with the Canon Utility to my Scratch drive. Then I preview all of them with VLC player for Mac. Then I compress to ProRess the clips I am going to use ONLY. And then I open a New Project on FCP and Import those files to my sequence.
That is my workflow...
I hope that helps!!
Ben Tolosa is offline   Reply With Quote
Old October 26th, 2010, 11:50 AM   #12
Originally Posted by Bill Pryor View Post
What I do is:
Just a quick question here: do anyone know the difference between the two ProRes' in MPEG Streamclip -- they both say 'Apple ProRes 422' and are listed next to each other.
-- peer
www.NoPEER.com
Old October 26th, 2010, 04:11 PM   #13
Not sure this is any different than other people but I have been making a copy of the Card with the footage so it is still in the EOS_Digital format to a Harddrive not just a copy of the internal data files and then importing using Log and Transfer converting to Prores. If you lost the ESO-digital structure but not the Mov files you can use Mpeg Streamclip or you can try and add the proper files to another EOS-Digital folder (if it is not s disk image) and then use Log and transfer.
Old October 27th, 2010, 01:32 PM   #14
I've burnt short HD videos through compressor (FCS3) onto regular DVD-R in Blu-Ray format. I think you can probably fit up to 20-30min of HD onto a regular DVD-R, and if that is all you need for playback I think that is better than paying a lot more for a blank Blu-Ray disc, they've gotten cheaper, but still not that cheap compared to DVD-Rs.
-- peer
Not sure, but MPEG Streamclip can pull from FCP's installed codecs. So you can always look to see what ProRes flavors FCP has & try to deduce from that.
Zach Love is offline   Reply With Quote
Old October 30th, 2010, 05:45 AM   #15
An important tip:
Many are stating that you cannot use FCP Log and transfer window for 7D files once the files are taken off the card or camera, ie, the .mov's only. There is a simple workaround - place your downloaded 7D files in a new folder titled DCIM. In L & T just navigate to the DCIM folder and FCP will see and pull in all your 7D files.
This method is far superior to streamclip. FCP allows you to make in-out points and add logging info and even timecode .... plus its very very fast.
