Pre-striping Compact Flash Cards at DVinfo.net
Canon EOS Crop Sensor for HD
Old November 18th, 2010, 09:45 AM   #1
Hello, not been on the board for a while but I do need to upload the underwater footage our students shot and the projects, will soon!
Anyway, I have a technical question.
I want to start pre striping P2 cards using P2 CMS which I understand and it works fine.
Can you do the same with the Compact flash cards? Would aperture do this?
I basically want the students to be able to add metadata to cards before they shoot.
Craig Campbell
Craig Campbell is offline   Reply With Quote
Old November 19th, 2010, 05:56 PM   #2
Compact flash is like a hard disk in as far as it allows the computer within the camera to write files to it. Nothing more, nothing less. There is no striping, no time code etc etc.
Your computer will read the files. Any timecode and meta data is in the files, not somehow otherwise on the card.
No striping required! Simply format the card in the camera and start shooting.
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply With Quote
Old November 20th, 2010, 11:14 AM   #3
Personally I like formatting any media in the device I am going to use it in rather than relying on any other device to format. Gives me the opportunity to see how the gear which is going to use it likes it.
Old November 21st, 2010, 05:42 PM   #4
Ah sorry, think you got confused with what I meant.
With the P2 route, I can write metadata using P2CMS that I can then add to my clips before shooting. So when they go to shoot they can load up the specific metadata profile and stamp it to the card. Anything that is then shot will have the extra metadata which may be shooter name, location, producer etc.
I understand how this can be done after someone shoots on a DSLR I just wondered if there was any way to do the same as I do with the P2.
Old November 21st, 2010, 09:07 PM   #5
I'm not aware of any metadata being included in the MOV files for the 7D, certainly nothing that I've been able to find.
Kin Lau is offline   Reply With Quote
Old November 21st, 2010, 11:51 PM   #6
The metadata is written to the .THM file that is associated with each .MOV file. It is a JPEG thumbnail with all the regular EXIF data e.g. shutter speed, aperture etc
Old November 30th, 2010, 01:30 PM   #7
The THM is only good for the initial settings, easily separated from the MOV, and it's not really recognized by most programs I've seen.
Old November 30th, 2010, 11:33 PM   #8
The Canon FCP plugin is the only program that I know of that actually uses the .THM files.
Old December 10th, 2010, 10:43 AM   #9
Ok thanks, will look into it, we simply add the desired metadata at ingest if needed, thank you.
