Question about mounting a Israeli Arm at DVinfo.net
Canon EOS Crop Sensor for HD
Old December 10th, 2010, 11:20 AM   #1
I just bought a Israeli arm to mount my Marshall 7" monitor. My question is where do I attach the other end of the arm is it to the tripod head? The two female to male thread adapter that came with the arm does not fit on the tripod head one is too big the other two small. Do I need to buy a different size thread adapter and if so which one? (I have the sachtler FSB) I also notice there are different Israeli arms available I'm not sure if the one i bought will support the weight of a 7" marshall monitor with battery. Delvcam LCD Monitor Mount DELV-ARM B&H Photo Video
thanks
-kAj
http://www.sweetproductionmedia.com/
Kajito Nagib is offline   Reply With Quote
Old December 10th, 2010, 12:21 PM   #2
I use a 15mm mini-rail/baseplate setup under the camera, and then use a Zacuto mini-rail mount to support the arm & monitor. But there are a number of ways to do this.
Good Luck!
David W. Jones
www.joneshdfilms.com
Old December 10th, 2010, 01:11 PM   #3
zacuto base plates are expensive is there a cheaper solution?
-kAj
Old December 10th, 2010, 01:59 PM   #4
Hey Kajito,
Not sure which dealer you bought this from but Abel Cine Tech in NY can guide you through this process. You might end up attaching the arm to the Hot Shoe with an adapter. The 7 inch monitor may be too much for that attachment point.
Old December 10th, 2010, 04:35 PM   #5
Contributor
ikancorp.com:
ELE-15RDA
15mm Rod Adaptor
$49.95
ikn #: ELE-15RDA
Specifications
Dimension: 1.38" x 1.06" x 0.61"
Weight (lbs): < 1oz
Shipping Weight: 1
Features
- powder-coated black
- machined aluminum
- completely modular
Old December 10th, 2010, 11:25 PM   #6
Originally Posted by Bill Pryor View Post
ikancorp.com:
ELE-15RDA
15mm Rod Adaptor
$49.95
ikn #: ELE-15RDA
Specifications
Weight (lbs): < 1oz
Shipping Weight: 1
ELE-15RDA 15mm Rod Adaptor
ok ill check it out.
-kAj
Old December 10th, 2010, 11:27 PM   #7
Originally Posted by Daniel Epstein View Post
Hey Kajito,
i bought this at B&H. i've been using the hotshoe but on windy days the monitor rocks back and forth. also i want to free up the hotshoe to attach other things like a mic.
-kAj
