TimeLapse at DVinfo.net
Canon EOS Crop Sensor for HD
Old December 20th, 2011, 09:16 AM   #1
TimeLapse
Hi Guys,
I looking into purchasing my first Timer Remote so I can create a 5-10 second piece of footage of clouds going over a house from night till day. I am planning to camp out with my Tamron 17-50 and 600D and some hot coffee! Does anybody own this remote
if not any reason it can't do what I need it to.
Tariq Peter is offline   Reply With Quote
Old December 20th, 2011, 11:05 AM   #2
Re: TimeLapse
I haven't used that brand. I've had success with an Aputure timer for the 5D2.
Some tips:
* An AC adapter would make sense for this shot. You don't want to be replacing batteries.
* A BIG memory card is a must.
* You can shoot HDR (three exposures) to capture night, twilight, and day. Yet more memory required!
* For an all day shoot, you will want a VERY long interval to keep the memory requirements reasonable. This might allow you to shoot RAW. I've read that small RAW is not good. If RAW is too big, go for JPEG.
* If you want smooth motion, you will want a ND filter, probably a 1.8 (4 stops) or more.
* Stop down for deep focus and a long shutter speed.
* For small aperture shots, the camera will open and close the iris for each shot. Every time it closes, it will be slightly different. That causes flicker. To solve it, set your aperture (to, say, f/16), press the DOF button, and untwist the lens.
Best of luck!
Jon Fairhurst
Old December 20th, 2011, 11:10 AM   #3
Re: TimeLapse
Also, if you want the proper exposure from day to night, you either use av with some possible flicker, or run bulb exposure with this guy:
How To Order
Greg Fiske is offline   Reply With Quote
Old December 20th, 2011, 11:53 AM   #4
Re: TimeLapse
That looks exactly like one of the cheap timers that I have. They work great. Here is a link to the very first timelapse that I created using my 5DII including a technical description of how I did it
I have come to realise that for simple timelapse of clouds it's much easier just to shoot a few minutes of video & speed it up in post than to deal with hundreds of still images.
Old December 21st, 2011, 01:52 PM   #5
Re: TimeLapse
I've had that one from Amazon. It worked absolutely fine and was very easy to use. I use the past tense because the batteries leaked and killed it. I still plan to buy another - I'll just take the batteries out while not in use.
Ben.
Ben Giles is offline   Reply With Quote
Old December 25th, 2011, 05:45 AM   #6
Re: TimeLapse
Try the Magic lantern hack. I am sure you will be impressed with it.
And best of all it's free. check out some of the youtubes
magic lantern time lapse - YouTube
Donald McPherson is offline   Reply With Quote
Old December 26th, 2011, 03:59 AM   #7
Re: TimeLapse
The RS-60E3 is just a remote shutter control, without any timer functions. If you can tether to a laptop, you can use the Canon Utility software that came with the camera and connect the camera to the laptop via a long USB cable and setup the timer functions in the software program, in which case you won't need to buy a hardware timer.
I don't know if there is an equivalent to the TC-80N3 Remote Timer Control for the 60D. The TC-80N3 won't work with the 60D due to the type of connector it uses. It works great on the 7D. Someone came up with the instructions on how to modify this timer so it will work with the 60D.
http://www.camerahacker.com/Canon_Ac...E3_Convert.php
Mark
Old December 27th, 2011, 05:52 AM   #8
Re: TimeLapse
Camera Hacker: Converting N3 Accessories to E3
Mark
While the Canon RS-60E3 is indeed only a remote control device the one that Tariq linked to is a timer for the 600D (amongst other cameras). If you look at the item description & read the feedback it is clear that it does work as an interval timer.
Old December 27th, 2011, 02:23 PM   #9
Re: TimeLapse
I stand corrected...
I Googled the model number and got the authentic Canon version, which didn't have a timer function.
Apparently Neewer makes this timer that Tariq is looking at and they give their product the same model number as the original manufacturer' items; same as with the Sony RM-S1AM Timer.
According to a video on fstoppers.com, they also produce some totally fake products like the Nikon battery grip discussed in this link.
Fake Nikon Gear Alert! D7000 MB-D11 Knockoff | Fstoppers
Mark
Old December 28th, 2011, 06:55 AM   #10
Re: TimeLapse
Do you sometimes wonder if the original poster ever reply s to his post.
Old December 28th, 2011, 03:47 PM   #11
Re: TimeLapse
Magic Lantern is very handy.
Event Videography, New England
www.timothybakland.com
Tim Bakland is offline   Reply With Quote
Old December 30th, 2011, 11:24 AM   #12
Re: TimeLapse
Thanks guys. I have ordered it from Amazon and looking forward to using it and sharing my results with you all over the next few weeks.
Old January 3rd, 2012, 12:12 PM   #13
Re: TimeLapse
I played with the Magic Lantern timelapse feature this weekend. It is a very handy addition to my T2i. It's not as simple to use as a timelapse controller, but does a bang up job of controlling the camera. One caveat... don't try to use it on New Years' Eve when you're around those who have had a few to drink. They tend to ask too many questions, get grabby with the gear, or stick their faces in front of the lens to "get their picture took".
Other than that, it's a neat "free" add on!
Bob Krieger is offline   Reply With Quote
Old January 3rd, 2012, 03:38 PM   #14
Re: TimeLapse
What are the pros and cons of Magic Lantern? I am so scared about installing it since my t3i is only 6 months old.
Old January 3rd, 2012, 04:04 PM   #15
Re: TimeLapse
Are there negatives? I've only seen positives: easy timelapse, continuous recording, audio levels, focus aids while filming, faster 3X button assign, white balance by KELVIN...
So much easier to change white balance!!
Also: all you need to do is get macboot and spend 10 minutes configuring all your SD cards the same way and then all your cards are ready to go. Unlike things I had heard in the past, you can format your cards without losing magic bullet every time. (Before format, Magic Bullet puts the files in the camera's memory and then re-transfers to your SD card, so it's always there. Your formatted card even remembers your menu settings. And you simply transfer those same Magic Lantern files to your other cards to have identical settings. Easy cakes!)
