Built in mic for 60D only recording on 1 channel at DVinfo.net
Canon EOS Crop Sensor for HD
Old January 10th, 2013, 05:42 PM   #1
Hi everyone,
Just wanted to check if anybody here has experienced this problem on their 60D. At first i thought it was the shotgun mic that was the problem but after i took off the shotgun mic off the cam, the built in mic was also only picking up on one channel. Is this a mechanical or firmware issue? I also use Magic Lantern.
Thanks for your input,
Kren
Modern Wedding Cinema for the Modern Bride
www.verticalvideoworks.ca
Kren Barnes is offline   Reply With Quote
Old January 11th, 2013, 12:32 AM   #2
Re: Built in mic for 60D only recording on 1 channel
Check your magic lantern audio settings. Did you set it to L:INT, R:EXT? That sets only one channel for the internal mic even I'd you take off the shotgun mic.
Chris Hsiung is offline   Reply
