Frame rate question at DVinfo.net
Canon EOS Full Frame for HD
Old June 13th, 2009, 05:24 AM   #1
Frame rate question
I am using 5d2 footage with XDCAM EX3 one. Edit in FCP. My usual worklfow was: using Compressor and transcoding 5D2 clis to ProRes HQ, 30 fps. Then I would change frame rate to 25 fps in Cine Tools.
But, yesterday I discovered I get much less aliasing artefacts in 5D2 footage when transcoded with MPEG Streamline to XDCAM EX 1080p codec. By far better results.
The problem is: once I transcoded 5D2 footage to anything BUT ProRes, I can not alter frame rate in Cine Tools. That option is being grayed. And, since I use 5D2 footage for general shoots, I do not mind them being slightly slowed down. On the contrary.
So, the question obviously is: is there any other way to alter 30fps to 25fps of the clips taken by 5D2 and transcoded into XDCAM EX with MPEG Streamline?
And why the heck can't I do it with Cine Tools?
Any suggestion will be highly appreciated. Thanks.
Daniel Ridicki is offline   Reply With Quote
Old June 13th, 2009, 08:04 AM   #2
Try this Film Look Deinterlacing for DV - DVFilm Maker, aka DVFilmmaker.
Rickey Brillantes is offline   Reply With Quote
Old June 13th, 2009, 10:49 AM   #3
Been a while since I've done this but I'm pretty sure cinema tools doesn't re-time interframe codecs such as XDCAM EX.
My latest short documentary: "Four Pauls: Bring the Hat Back!"
Evan Donn is offline   Reply
