Eos 5d mark 2 problem? at DVinfo.net
Canon EOS Full Frame for HD
Old November 1st, 2009, 09:29 AM   #1
Hi everyone...
October 15th buy the 5D, last firmware, etc, ok.
October 16th, 17th, etc... everything works great.
October 29th some fliker when panning on video mode.
October 30th start to freeze frames and drop frames.
Whats happened? Hardware or firmware problem?
I had 15 days to test the machine, the house where I bought will exchange a new one. Does the new camera comes with the same problem?
Gustavo da Luz is offline   Reply With Quote
Old November 1st, 2009, 09:32 AM   #2
The 5D Mark II can have problems with certain CF cards, or with a CF card that hasn't been formatted in the camera. Try switching cards, and make sure you format the cards in the camera.
me@facebook: http://facebook.com/stevemallerphotography
Steve Maller is offline   Reply With Quote
Old November 1st, 2009, 09:37 AM   #3
I forgot to say. It happens even without being in rec.
Old November 1st, 2009, 01:35 PM   #4
So when it happens when you're not recording, are you sure anything is actually going wrong? The progressive image will produce a flicker or strobe effect while panning.
Can you upload a short clip that shows what happens when you are recording?
Can you tell us what cards you are using?
Canon 5D Mark II || L-Series Lenses || Steadicam Pilot || Final Cut Studio
www.lovestorymedia.com
Erik Andersen is offline   Reply With Quote
Old November 1st, 2009, 03:55 PM   #5
Hi...
The card is a Lacor 16Gb PRO...
I switch on the lcd and before i start rec i can see like a drop frame and the flicker.
Here is the short clip, first with drop frame, second with alot of flicker.
I see various clips from 5D and i dont see anything like these.
NOTE: Only drop frame and flicker, the other thing like horizontal cut line is from vimeo.
password: canon
if the clip is not available its because is still converting by vimeo
Old November 2nd, 2009, 12:40 AM   #6
I downloaded the original file, there are two missing frames in the first shot. Doesn't look good at all. Lacor, not a brand I've ever heard of. What's the write speed on this card? Have you tried other cards? Maybe something by Lexar or Sandisk, the cards most of us use? I've also used Kingston 133x, but use UDMA cards if you have the budget.
By the way, do you see your buffer indicator showing up on the screen?
Old November 2nd, 2009, 04:19 AM   #7
Hi Erik. Its a Lacor Pro 155x. I thing its good. I tried Sandisk and its the same.
I never see the buffer up. When i start record its show up one square, thats it, never shows again. Maybe the 5D has problems, i dont know.
Old November 2nd, 2009, 10:39 AM   #8
Remember that changing the aperture on-the-fly can cause dropped frames, and using the automatic focus (contrast detect) will often brighten the exposure for a sec. However, locked down, neither should occur.
Bill Binder is offline   Reply With Quote
Old November 2nd, 2009, 10:57 AM   #9
The only time I've had a dropped frame is if I shot a still while recording. So I think there is a problem with your camera.
Old November 2nd, 2009, 04:38 PM   #10
Well, I'll have to wait to receive a new 5D. Thank you all. :)
