Do any follow focus units fit large diameter lenses? at DVinfo.net
Canon EOS Full Frame for HD
Old March 14th, 2010, 02:06 PM   #1
I would like to fit a follow focus onto a Canon 70-200mm IS f2.8. That's a pretty big lens with a diameter on the focus ring of about 11inches (28cm).
The D-focus video shows it on a big Canon 85mm but I'm not sure how big that lens adaptor is. Many other manufacturers seem not to make any large diameter adaptor rings at all.
I also use the 70-200 with a Canon 2x adaptor, so a long rail system will be needed as well.
The camera body to lens focus ring distance is just 9.5inches (24cm)
Anybody know of a suitable follow focus and rails?
David W. Taylor is offline   Reply With Quote
Old March 14th, 2010, 03:04 PM   #2
I just checked redrock micro.. You can get their follow focus, long rails and their dslr base plate. You will also need a cheeseplate so that you can mount it on your tripod.
You need lens gear size C according to the people at redrock. If you get the 3 pack and get B, C , D then one will fit and you can use the other 2 for lenses.
Red Epic available for rent, starting at $500 per day, Scarlets, and Lenses available too. rentals.maddalenamedia.com
Louis Maddalena is offline   Reply With Quote
Old March 14th, 2010, 03:48 PM   #3
I easily fit a CineCity follow focus ring on this lens:
-- peer
www.NoPEER.com
Old March 17th, 2010, 07:12 PM   #4
Hi Peer
i just bought the cinecity follow focus ring with rail system. I think the follow focus it's ok, but i'm not happy with the rail system. What are you using in the video? what do you recomend?
Pedro Martins
Pedro Martins is offline   Reply With Quote
Old March 19th, 2010, 09:10 PM   #5
We recently launched a new version of our 360 degree full rotation lens gears for lens with focus rings up to 4.5" on diameter.
Cheers,
Dennis Wood
www.cinevate.com
Dennis Wood is offline   Reply With Quote
Old April 6th, 2010, 12:05 AM   #6
Originally Posted by Pedro Martins View Post
Hi Peer
Sorry to get back to you so late (been gone from DvInfo too long ;^)
Anyways -- also I got the rail & shoulder sys from CineCity, but quickly decided to get rid of it. Instead I did a DIY with components from Redrock, DFocus, and Home Depot. The carbon rods were custom made by a small company, CFTS, in Salt Lake City.
-- peer
www.NoPEER.com
Old April 6th, 2010, 11:42 AM   #7
I use the redrock lens gears with no problems on the 70-200.
Cody Dulock is offline   Reply With Quote
Old April 7th, 2010, 06:03 PM   #8
Hi David. Are you sure you don't mean 11" circumference? If it's really 11" diameter it must be quite a monster.
Richard
Richard Hunter is offline   Reply With Quote
Old April 7th, 2010, 08:13 PM   #9
Canon 70-200mm diameter is a bit larger tan 3", so I'd say it's normal and any FF will do,
(Cinecity, Cavision, Cinevate, Zacuto)
but if you really need something for the monster lens here you go:
Introducing OConnor’s CFF-1 Studio Follow Focus | CineTechnica
I love this place!
Old April 7th, 2010, 10:30 PM   #10
Originally Posted by Buba Kastorski View Post
Canon 70-200mm diameter is a bit larger tan 3", so I'd say it's normal and any FF will do, (Cinecity, Cavision, Cinevate, Zacuto) but if you really need something for the monster lens here you go: Introducing OConnor’s CFF-1 Studio Follow Focus | CineTechnica
Yeah, the O'Connor is truly the Bugatti of follow focuses, and ringing in at $4,500.
-- peer
www.NoPEER.com
Peer Landa is offline   Reply
